318 camshaft timing question
Ok, sorry. I had military duty the past several days. I'll try to answer everything.
It will ping no matter the distributor. I used 2 different HEI converted, stock distributors. I tried welding the slots, light and heavy springs, vacuum pods and still pinged. I got the ready to run MSD distributor and have better luck with it, but still does it. Tried 2 heavy springs and it ran like a slug and pinged on WOT. Currently it has 1 heavy and 1 blue spring in the distributor and the factory advance stop bushing. (Next weekend I plan to put the next larger stop bushing in the MSD). It has good throttle response, mpg and drivability. With those springs in it.
I eliminated the heat crossover butterfly, so it is wide open for stock manifolds.
The carb came with #52, 6.5pv, and 25 squirter. It now has #55, 10.5pv and 28 squirter. I could possibly go 31.
I have used Bosch plugs, splitfire, Autolite 64 and 65. Currently I have the champion 11s in it. Haven't checked them since the fall.
I have also run it with and without the EGR hooked up. I also have another EGR valve to try that has a larger opening.
Did I answer everyone's questions?
Thanks
Thanks
I'll ask one more time. Where in the **** is the curve? I can't be any nicer than that. People are trying to help you but you can't answer one simple question.
We know your initial. We know your total. What is the shape of the curve?
Because it matters.
You can NOT shove an assload of timing at around peak torque and not have it rattle.
And drop your coolant temp. If it's over 180 get it down. If you care more about emissions than tuning and power then get it hotter than that.
Cold temps and thin oil makes power.
Initial timing and total timing have very little to do with when and why it’ll ping. You need to work on the shape of the curve. Specifically around peak torque where it will most likely rattle. The vacuum advance may be a little too early also which can influence the rattle. Step 1. Is always to verify your timing marks on the balancer.
When I assembled the engine the timing marks were on point. I have a standard timing light and recently bought a new goal back timing light and they both agree with each other. Not saying that it hasn't slipped but I plan on verifying that this weekend.
Because it matters.
You could be nicer than that. I understand he hasn't answered your question yet. He has answered other questions and provided lots of other information. He may not have the information you want yet or he may need to have it explained to him how to get the information you want. Either way If that's your version of "can't be any nicer" you need to try and little harder.
I'm trying to answer the question. I'm using the MSD chart silver spring and light blue with the blue stop bushing.
Thanks for the tip. My time is my time.
He’s been asked to show the curve. So either he doesn’t know or he won’t say it.
Either way, that’s as nice as I am. I asked once very nice.
If you want to go in circles with these guys on this **** that’s on you.
I’m not doing it. I don’t get paid for this.
You don’t like the way I talk? Answer the question. Or not. I do not give a single ****.
He can continue to rattle his **** to death. It makes zero difference to me.
What he has said is he’s done it all and nothing works. So he can sort it out on his own.
Look at the chart. Even if it’s correct, and most of the time it’s not for several reasons, with the heavy spring you are adding 18 F’ing degrees at 3000.
So, if you start with just 12 initial you’ll have 30 degrees of timing at 3k. That’s too much. Plus you are dumping vacuum advance on it, and being a mechanic device it takes TIME for it to come off.
That’s why we keep saying what does the curve look like. Because it matters.
Use your timing light. And your tach. Plot the curve.
I’ll do you a solid because 92b thinks I’m a prick.
Take your distributor out, put it in a box and send it to me.
I’ll put the curve in it and send it back with a graph that shows what the curve is.
Just pay the freight both ways.
Ok. The chart is wrong. Almost always. Get a timing light on it and tell exactly where max timing occurs.
Thanks. I don't have a tach on the engine. I have an old tach and dwell meter I could use, but it only goes to 2500rpm.
I had been using the MSD chart and what it says. I will put a larger advance stop bushing in it. MSD does not say anything about tuning the vacuum advance pod, so if it is tuneable I would like to limit it as well..
I have a 160* thermostat in it also and it runs pretty cool. I will unhook the vacuum advance tomorrow before work and give it a whirl and see if it still pings.
Thanks
Kind of sounds like Rat Bastid... Hmmmmm
Thanks
I’m saying put it in a box and I’ll fix it for free for you.
Or not.
have you looked at the piston tops and combustion chamber with a camera? not read back through to see if it's a new build but if not it could need an old fashioned decoke. if there's carbon build up in there it'll ping good for sure.
neil.
No chance of that.
Obviously. It worked for awhile on the wife but after the honeymoon that ended.
Edit: the wife just said she didn’t buy my malarkey from day one. She married me because she felt sorry for me.
Marriage is bliss. That’s what I’m told anyway.
It gets frustrating when people come on here for help, get asked the same questions over and over again and either don't answer or answer so late, it doesn't matter anymore. I get it he's in the military and I applaud and thank him. But either he wants help or not. He could have begun with "hey guys, I'm active duty military so it may be some space between when I can answer questions" but no, this info is not found out until much later. ....and I like the OP. Far as I'm concerned, he's one of the good guys here. Now, all THAT said,
When I first built my slant 6, I spent some time chasing down a detonation issue. With around 175-185 PSI cranking pressure (another thing we've asked the OP about with NO answer), I tried several things. But, THE BIGGEST NUMBER ONE THING that made the most difference and ultimately stopped the detonation was getting the coolant temp DOWN. Now, it will run on 87 and I cannot MAKE it detonate. It doesn't run nearly as well as on 90 non ethanol, which is what I run in it all the time now, but no matter how much I lug it, it will not ping.
There is a spectrum of people on this forum. Some who are serious about this hobby and some who are not. Some who are knowledgeable and some who are not. Some who have alot of time to pursue this hobby and some who don't. Some who have been at it for a long time some that are new. Etc. Etc. Etc.
A typical "I need help thread" starts with someone saying "I have a problem with ...." followed by responses that come from people suggesting do this or do that, check this or check that or give me more information please. Etc.
The op gets to choose what advise they take or questions they answer or how quickly they respond. Based on what they think is going to help them and in a time frame that their busy or not so busy lives allows them to do.
Some people like to follow along with the journey quietly and others participate. Those who participate I hope are doing so because they like to help people and don't expect anything in return. It's nice when people show appreciation but if you are expecting gratitude or someone to listen to you and only you or that they respond in a time frame that suits you then you might want to take a hard look at why you are helping people to begin with. Is it for them or for you? We have to remind ourselves that we all have egos and they want to be fed.
If the op doesn't respond to your request in the time frame you deem proper, why get angry? Your out nothing but time spent on a forum you like to spend time on.
There is a spectrum of people on this forum. Some who are serious about this hobby and some who are not. Some who are knowledgeable and some who are not. Some who have alot of time to pursue this hobby and some who don't. Some who have been at it for a long time some that are knew. Etc. Etc. Etc.
The op gets to choose what advise they take or questions they answer or how quickly they respond. Based on what they think is going to help them and in a time frame that there busy or not so busy lives allows them to do.
Yeah and I think you just typed all that out just to take pride in your own input. I mean seriously, your whole post states what everybody here already knows, so you just want to see yourself blab. Goodbye.
Unreal.
I have a stock 1988 roller cam 318 that I rebuilt some 30,000 miles ago. Stock cam, lifters etc. Dingle ball hone rebuild and freshened up #302 heads. Cast 4bbl intake, Holley 390cfm and a MSD ignition. Runs great, get 14mpg in my Ramcharger with 3.21 gears.
The question is that this dude is loud. I just switched from the dual exhaust to the factory single 2-1/2" exhaust and catalytic converter. I thought that the duals were the reason why it is loud, but not the case. It's loud at the engine especially for a stock Ramcharger.
Another issue I have is It needs 93 octane or the thing will ping like crazy. I have the ignition timing at 10*, total 32 and with vacuum like 50ish. I'm using the med-heavy springs in the MSD distributor and the factory advance stop in the MSD. It doesn't matter what I do timing/distributor wise, it still does this.
Now, i used a stock single link timing set, but I do not remember the brand (I rebuilt it 5 years ago) but it has me wondering if it is off and it has the cam really advanced and causing me to have high cylinder pressure, in turn causing the pinging and such. Every year the dude also fails emission testing with high hydrocarbon and Co2 with my EGR hooked up.
Any thoughts on something I may be missing?
Thanks!
Paul
Elevation Delaware is what? 850 ft ?
Your 318 is gonna be down on power, for several reasons. This means that in the Ramcharger, which may be say 30% heavier than an A-body, she's gonna need a lot of throttle, to get moving. 3.21Hiway gears and tall tires are gonna make it worse as will a factory low-stall convertor.
as would the extra weight of a 4x4 system.
All in all, if that is what you have, you just have a bad combo.
The compression test will steer the guys in the right direction.
There is
a lot of in-fighting going on, on FABO right now; lots of Alphas.
IMO, the site is in a stage of "going to the dogs", just like many other car-sites are these days; it's just a bad time in FABO's history.
However, there is a very good knowledge base here, and if you tread lightly and co-operate, eventually you will get what you need.
Right now, a compression test will calm them down.
As for me, I'll just say that detonation, in your case, is likely due mostly to a crappy chamber, and nothing you do will ever let her run on 87E10.
Well ..... maybe not nothing.
Alloy heads should cool the chamber enough to quiet things down.
BTW
To answer your question about cam-timing, you don't have to peel the front of the engine off to check it. You can get a very good idea, using the following method; but it depends on eliminating a couple of variables.
This is not my method. I got it from a Book by Smoky Yunich. It has a name, which I forget, but, what it amounts to is positively locating "Split Overlap".
1) verify the TDC mark on the balancer, using a piston-stop.
2) remove the driver's side valve cover.
3) find split overlap for #1 cylinder.
4) read the advance on the balancer.
a)if you are within 5degrees of TDC, on the advance side, there is no point in degreeing the cam.
b) If the cam is retarded, the pressure will be down, and the power will suck.
c) If the stock-cam is advanced more than 5*, pressure will be up, which makes the bottom end snappier.
d) It's all about the pressure. Which points back to the Compression test.
The variables to watch for are;
1) a slipped TDC mark
2) hydraulic lifters that bleed down during the test.
3) bent pushrods.
4) sunken valve seats or a less than stellar valve job.
The proper way to do this, is to take the intake off and put a straightedge across the lifters. However, I don't see this as any easier than pulling the timing cover. With a stock cam, I have had very good success with a straight edge across the retainers; at least enough to tell me if I want to go thru the trouble of degreeing the cam.
However;
A compression test will definitely hint at the same thing, and by comparison, is just too easy. and
sooner or later, you are gonna need a tach for diagnosis. Mine is right on the dial-back timing light.
I used to run a 73 low-compression LA 318 with open chamber iron heads, in an 84 D100, with 3.23s, a big Thermoquad, 28" tires and with gobs of ignition timing, that did not detonate.
My secret was a 2800 convertor. That combo would roast the tires in First gear. the point is, just have a little patience.
As for a timing curve, you need to read and record your mechanical timing about every 400 rpm, all the way to 4000rpm. Then plot the points on a graph paper. and
The vacuum advance needs to drop out very rapidly; instantly would be good, especially if you have lots of it.
Once again, mine has 22 degrees in it and my total cruise timing can be as high as 56*. The point is, that when you press on the gas pedal, that VA has to decay as fast as possible.
If you don't already have a 2800 stall, or higher, My thinking is, that ou should have, and your cruise rpm should be NOT LESS THAN 2400rpm, which will speak to your gearing and tire size. The 318 may not still get 14 mpgs anymore, but-up, some sacrifices may have to be made. You gotta get rid of the detonation.
Detonation is ignition of an air-fuel mixture from multiple points in the chamber, resulting in an audible shock-wave which usually breaks parts.
The cause is usually excessive heat in the chamber, for the detonation resistance of the fuel.
The heat can come from; Preignition, or from excessive cylinder pressure, lean-running, hot spots in the chamber, or excessive heat in the cooling system.
Going back to your cam-timing question;
It is hard for me to imagine that no matter how far "over-advanced" your cam might be, in the stock 318 engine, that the pressure could get high enough to cause detonation, and yet, the engine would still idle.
I say that because, I have, on purpose, over-advanced LA318 cams, looking for pressure, and they did not detonate. Mind you, the LAs, from 73 on, are 8/1 advertised, engines, which at my 900ft elevation, can barely make 135 psi in the first place. Adding cam advance to the factory lo-C LA318 is a total waste of time. ..... but I had to learn that.
But I also found out that they do not tolerate much cam retard, before the lose power.
BTW
Lean running with hot sparkplugs is an easy way to induce pre-ignition, which quickly leads to detonation.
Well heck, ALL us already knew THAT.
Everyone,
I apologize and do appreciate your help. I'm going on 13 days and next schuled day off is in another 4. I think that I'm answer questions with what I know for certain on what I have done already. I have only gotten an hour or two in the past week to get out and try to do anything with it. I keep thinking that I'll go out at lunch and try something, but my shop chief is in and just, well...
So, I will get a compression test done. Just need a few more days.
I believe that the carb is lean. It runs a lot better while the choke is partially closed and cold. At the very least tomorrow, I want to put a larger squirter in it.
Is there a spark plug that I should use with the 10-15% ethanol gasoline that would be better than the Champions? I'll order them from Rockauto.com and have them here by the weekend.
Yeah, my elevation is darn near sea level. There is a point at the inlet, it seems like the road goes below sea level at the base of the bridge, but the dunes give it that optical illusion.
Thanks for everything and I hope to get something done tomorrow
