jos51700
Green Bearing thread connoisseur
I finally found a NOS aluminum carrier for my 8 3/4. When setting up a ring and pinion for a brand new 742 setup, there's no spacer to start with. How is this spacer chosen for an unknown setup (I don't even have an old housing sitting around.).
Also, I'm going to run a Eaton Tru-Trac. I'm seeing some references to 33 spline, and 30 spline axles in the literature. I have aftermarket axles in my current housing and I was just going to reuse them. Is there really two different spline counts?
