Reminds me of this...Dilithium crystals. You can’t go wrong. Properly mounted in a tri-linear phasolator, they will outperform any energy source known to man. Just don’t let them overheat.
Yeah sounds good, I’ve got an idea, let’s hook ‘em up to eight arc welders mounted in the boot! Time them off a crank trigger! We’ll make millionsGap them at 15 feet minimum.![]()
Yep like said. I stick with points.After reading too many conflicting opinions, I stuck with points. Haven't failed me yet.
I now have one of each. My 64 has been converted to Mopar Electronic. It works well now. My 66 is the factory dual point. I think I am going on 10 years on the same set of points. (may be 10,000 miles), and my 70 Swinger has Pertronix. So far, all 3 work perfectly.Yep like said. I stick with points.
How many still keep a points distributor as a back up ( in a box in the trunk!?).
I had Bazza's Lucas distributor completely rebuilt, and the guy that did the work threw-in two spare sets of "Rolls Royce" points (turns out the R/R takes the same set of points as the Lucas). Given the amount of miles Bazza puts on his car annually, I doubt he'll ever need either one of them.Yep like said. I stick with points.
Well, making an ignition module is on my to-do list after finishing up the voltage regulators. But the ignition module will not use any black market nuclear weapons components.Just checking to see if this idea made it past April 1.... lol
Nope I bet they have not. I ran points for many years. Kept an empty file, matchbook, and a screwdriver in the ashtray too. All you old timers know exactly why too.After reading too many conflicting opinions, I stuck with points. Haven't failed me yet.
Their nukes have recycled washing machine guts for circuitry anyways. Just hit up your local appliance parts storeWell, making an ignition module is on my to-do list after finishing up the voltage regulators. But the ignition module will not use any black market nuclear weapons components.
And even if I did bribe People's Liberation Army officers into parting out a few nukes for their circuitry, I doubt that would stop the arguments over which ignition system was the best.
Interesting. My former employer removed all their VCB’s (Vacuum Circuit Breakers) in their high-voltage switching equipment years ago because they emit X-rays when operating.All seriousnous aside, I thought the OP was all April Fools an' such. I have never HEARD of a krytron tube. Well they are REAL. Real and also radioactive!!!
I have seen this one before, an effort by Tung-Sol using a Thyratron tube. I believe at one time, there was a better article
Thyratron tubes were used in my day to trigger pulse radar transmitters. Very high voltages and very high (in some cases) peak power. They are the high power, high voltage and "vacuum tube" (actually gaseous filled) equivalent of a modern SCR solid state switch.
[/URL]
There's a reason my user name isn't Sane Scientist Matt.Tell me this, just where did you learn about the Krytrons?
Look this up, it might help with this project.
Oreilly's auto parts. Part # 121g
In stock a few months back.
Rick
It has its used, but I can never figure out its maximum rated voltage.Look this up, it might help with this project.
Rick
