I was always wanting a copy of the later model A's glove box liner. I knew that originally we (63-66) A owners had a molded glove box liner but it was made from paper! that sucks, since I live in Florida where paper and moisture sort of don't mix too well. So here is my latest attempt for a remedy. It's not perfect yet (overheated the plastic and got bubbles in it, miss-located a hole and had little bit of webbing to work with and a ***** of a time getting it off the mold) but hey it FITS and won't fall apart!
old one and a test new one
going in
in this pic you can see the hole I missed on (right upper screw dang it 1/8th off) and the small web on the same side lower corner. but it fits,works and WON'T fall apart in moist weather.
I am happy with it as a good part right now. But I'll continue to fix the webbing issues since I am going in the right direction finally
instead of just burning up plastic!
