ValiantRacing
I typed this in and this is what AI says, i would swear @Newbomb Turk is writing for AI
For drag racing, an engine with a larger bore and shorter stroke is generally preferred because it allows for higher RPMs and more power output. This is often referred to as an "oversquare" engine. [1, 2, 3, 4]
Here's why: [2, 3]
Rod Ratio: While bore/stroke ratio is important, rod ratio (the ratio of the connecting rod length to the stroke length) also plays a significant role, especially in high-revving engines. For very high RPM operation, rod to stroke ratios greater than 2:1 are typical. Rod ratios of 1.70 to 1.65 are also mentioned for Pro Stock drag racing. [1, 5]
Here's why: [2, 3]
- Higher Revs: A shorter stroke means the piston travels less distance with each revolution, reducing piston acceleration and allowing the engine to rev higher.
- More Power: Higher RPMs contribute directly to increased power output, especially at the top end of the rev range where drag racing engines are typically pushed.
- Larger Bore: A larger bore allows for bigger intake and exhaust valves, improving airflow and further enhancing power.
