If I remember right.....
EM did a dyno test of two otherwise identical short blocks, a long rod engine vs a short rod engine..... and didn't find any substantial difference. (bbc).
Well that proves Yupik was stupid then I suppose. Or, might I suggest their test was fucked? Maybe that would be the reason.
IIRC they used the same cam with both setups. That’s not right. They didn’t hook a blow by meter up either. That would tell a whole different story.
EM always (almost always) uses a 300 rpm/sec rpm acceleration rate. That’s too slow to do testing like that.
That’s why you see dual plane intakes look killer on the dyno and then they get their *** kicked at the track.
But that slow acceleration rate sure makes those power numbers look good.
