I wasn't planning on it. I went over the cam card specs with Jeff at TF and he assured me that the seat pressure fit Hughes' specs.Do you plan on shimming them at all to get the seat pressure up?
See, that's where I'm confused. Didn't he say the seat pressure for those springs is 150? Sounds like that 150 is at 1.900" installed height, not 1.950". Not sure it'd make any difference though, but you may want to double check.I wasn't planning on it. I went over the cam card specs with Jeff at TF and he assured me that the seat pressure fit Hughes' specs.
I agree, there's some ambiguity to the spring specs and to what Jeff was saying. If I take a conservative view and say the seat pressure is 138# @ 1.950", is that a reason for concern? It's 12# or 8% lighter than Hughes' cam card specs.See, that's where I'm confused. Didn't he say the seat pressure for those springs is 150? Sounds like that 150 is at 1.900" installed height, not 1.950". Not sure it'd make any difference though, but you may want to double check.
A good example is the windage tray above. The Magnum didn't originally come with one but I wanted to add it so I picked this up at Mancini Racing. The description clearly states its not stroker clearanced (I missed it when I ordered it). The tray cleared the counter weights but impinged on a few rod bolts. A little persuasion got the height we needed, but in turn it slightly increased the radius so the outer edge rested on the inside of the oil pan rail. The windage tray was ringed with a U channel edge. With a hammer and anvil we flattened the channel back into the tray. I also had to lengthen the slot in the tray where the oil pickup tube ran across. Total time was about 1/2 hour.This is not a stock rebuild with stamped steel rocker arms, iron heads, a single row timing chain and cast iron rings. Every component is an upgrade so extra care needs to be taken to maximize the potential of the engine.
Yes.did you say .065" thrust clearance
I love the contrast of the aluminum and that orange paint. It is mechanical art and a beautiful sight to see.
The whole Preload issue is a bit of a pickadilly for me too. What is correct? What is too much?
The 360 I bought last year, tore down in January and am building alongside the OP's 408 has Hughes 1.6 ratio rocker gear:
Look at the threads showing above the lock nuts on the adjusters. They are close if not exact.
When I tore down the engine, they were all over the place. NO cylinder had identical looking thread counts and I might know why. I adjusted mine yesterday and I had the intake off. Now...There is certainly a proper way to adjust these but I did it my own way, a method that makes sense to me. Feel free to call me out and tell me I did it wrong because I had no printed instructions.
I tightened the adjuster until the plunger in the lifter started to move away from the spring retainer at the top, then I went 7/8 of a turn on the adjuster and locked them down. One full turn equals .050". As I secured the lock nuts, the adjuster turned a slight amount more so I am just shy of .050" preload. The guy that had this engine before me had stamped steel rockers on the engine when he first built it then added the Hughes rocker gear later. He did not pull the intake when installing the new pushrods and rocker gear. What I noticed is that if you are relying on tension in the pushrod to determine a point of zero lash, you have gone too far. As I was doing the adjustment, I could spin the pushrod even after I adjusted to the final number where the lifter plunger was already .050 below the retainer ring wire. I suspect that the prior owner couldn't see that he was already depressing the plunger and that he had every lifter set to a different preload setting.
I don't have much experience with Mopar engines that have hydraulic cams and adjustable valvetrain. My red Charger has a solid cam and determining valve lash is simple. Feeler gauges between the roller tip and the valve stem and that is it.
I had several Chevys before jumping back into Mopars. They were simple...I'd use a cut down valve cover and start the engine. Back off the adjuster nut until the rocker clattered, tighten it until the clatter was gone and then tighten it another 1/2 or 3/4 turn and then move to the next rocker arm.
Here is an article written by Jeff Smith, a former editor of Hot Rod magazine:
The drawbacks of too much or too little preload:
I would think pushrod length is a factor. If 0.60" was added to the pushrod length when measuring the checker rods but preload was set for only 0.030" when assembling the engine, the pushrods would be .030" too long. I'm not knowledgeable enough to know what the implications are.
Greg and I attempted to determine one revolution height using rudimentary techniques, and we got close. Talking to Mike, he said the PRW adjusters are 20 threads/inch.BTW.. the adjusters are 24 threads per inch.. 1/24=.041 not .050.. not that .009 matters.. but..
