Yea, that's a bit tight for a bench lol
Little discourage here. Been spending a fair amount of time thinking about and looking at suspension mounting point and since I can't do any welding yet, I have just been sticking my head under the fenders and thinking. Thats when I noticed that the sheetmetal is wrinkled.
You can even see where the sheetmetal was when the undercoating was sprayed on.
Now that I look at the gaps, I can see that I should have looked deeper much earlier. The gap between fender and rocker is pretty big. The gap on the other side looks fine.
The car has some rust in the quarters and was obviously ridden hard, but I wasn't thinking jumping ditches. Not really sure what to do with it all now.
In the end, I will probably leave it alone and get it running and driving. But my gut says at the very least it will need frame work at some point before I reinforce the front. I thought the car was structurally good, obviously I was wrong.
I wouldn’t say that’s nothing but I don’t know that it’s worth worrying about either, I’ve seen some pretty bad gaps on these cars without any actual damage. I’d say you should take some measurements and compare them to the factory chassis measurements before you spend too much time thinking about it.
That sucks but may not be a huge issue, have you driven it? Does it drive straight and not wander about etc?
The stone guard on your duster is that standard? Mine also had that is it standard, Australian mopars dont have stone guard just undercoat. Man it was a mission removing it, its like chewing gum.
Finish it and drive it, potentially will never know. What level are you building the car to? Once driving a good repair shop could straighten it on a frame if anything is bent.
I wouldnt worry too much, unless building it to be a show car etc
As you look a long way in to now start fresh
Yea, I agree with the above comment. These cars have some pretty bad gaps. Yours doesn't look like anything too out of wack. Did you measure it compared to your other Duster? Your pictures look pretty normal to me
Have you done chassis connectors? If not the 6.4 going to most likely make some adjustments to the car its self lol
In the bottom picture does you lower fender not run in a straight line with the sill? My duster is the dame and i am thinking its a duster thing not an actual issue?Little discourage here. Been spending a fair amount of time thinking about and looking at suspension mounting point and since I can't do any welding yet, I have just been sticking my head under the fenders and thinking. Thats when I noticed that the sheetmetal is wrinkled.
