This is my first build using adjustable rockers, so this is foreign to me. I'm used to the OEM application where the shaft hold downs are torqued to spec and you're done.I actually ended up at 2 turns (.082) preload... at 1.5 turns or less i would get random noise... i did use used OEM lifters though..
P.S. i have actually changed preload on my motor 5-6 times.. from 1/2 turn up to 2 full... and ended staying at 2.
P.P.S. i believe the stock magnum/LA roller preload is like .125... and the lifters and do upto .160 (i think.. been awhile since i hunted for the nfo)
In your case, you've adjusted preload from as low as .0205 up to your current .082. This backs up the narrative that preload isn't an exact science. I'm also taking this to mean that pushrod length has a certain fudge factor built in as well. On my build, I had added .060 to the pushrod length but only had .050 adjuster length. When installing the pushrods I backed the adjuster to bottom out in the rocker arm and the pushrod plunger was slightly depressed; in theory it would have been .010 but I have no way to measure. I added one full turn to the adjuster which in theory would equal .060 preload.
Creating preload with the adjuster bottomed out is a little disconcerting to me. I can never 'zero out' my preload unless I go with shorter pushrods. I guess my takeaway for future builds is that during trial measurements, the rocker arm adjuster needs to be extended down at least as far as the anticipated preload amount, probably a touch more to give more adjustability during the final assembly. Is that how everyone else measures their pushrod length?
