Bullshit.
It wouldn't have cost them much to make them fully compatible with stock components. The pictures often are "stock" photos that are not 100% representative of actual reality.
Look, I'm not the type to immediately blame the manufacturer when I encounter a problem. We have all seen those guys and I absolutely am not one of them. I can fabricate and weld so it isn't as if I'm stuck on an island with this one.
This isn't the only issue Rich and I are having with these UCAs...
The left side UCA had mounts that were a strong 3/16" wider overall than the right side. Measuring over/over, the stock control arms were approximately 9 1/2". The 72 Duster I rebuilt last year was 9 3/8"
The PST left arm was just shy of 9 3/4", requiring me to mill down the aluminum end spacers/caps to get the arm to fit in. The right side went right in.
BOTH arms were installed with the alignment cams adjusted the SAME way....front cam OUT toward the fender, rear cam IN toward the engine.
Late last year, I used my gauges on the car and found it had 2 degrees of positive caster and bear zero camber on BOTH sides. This is with stock UCAs with offset bushings.
When we tried to align it today, the left wheel cam in with a fantastic 5 1/2 degrees of caster but only about 1/4 degree of negative camber. That is fine, I could give up a slight amount of caster to have a little more negative camber.
But....
When measuring the right side, it was 1 1/2 degrees of POSitive camber with 4 1/2 degrees of NEGATIVE caster.
The owner installed PST adjustable strut rods and they were installed at the same measurement of what the stock arms measured. We cranked the RIGHT side strut rod forward by 1/4" and rechecked the alignment. The camber was almost the same at 1 1/4 degree POSitive but the caster was still the same.
How could that be? I moved the lower ball joint forward by 1/4" and saw NO change in caster?
Well.....
Looking closer, the NEGative caster on the scale STOPS at 4 1/2 degrees. I tilted the gauge from it's base and found that I was surely well past the 4 1/2 degree number. Who the heck knows how much negative caster we have at this point. The RIGHT arm is simply built wrong.
We started measuring from several points and found that the zerk on the top of the upper ball joint is 1/2" further forward on the right than it is on the left.
