367 vs 410 Engines Masters
There only substantial if your gear them same. Cause again they make the same power just at higher rpms.
I know you want to play one up 'em gear war, that's why i say optimal is cause that's where one up 'em leads to anyways.
I don't known what you mean by one up em gear war. Unless it's this. The 410 can choose to have the same gear as the 367 and have a performance advantage all the way up to peak hp. Or the 410 can have the same performance as the 367 all the way to peak and have the benefit of a more highway friendly gear for Freiburger's challenger. That would be the 410 "one gear up em" the 367?
no, i meant 222. because 1/4 of a mile is double 1/8th of a mile. so it's that 1/8th mile number, plus it again gives you the 1/4 mile time.
everybody knows this.
i done heard the louvre is closed! besides, my masterpieces are too sacred for such commercialization! anyway i have my own museum. with black jack! and hookers!
And blow, you can never forget the blow :)
Not really, don't matter, after 11 pages if you can see how overlaying the power curves can help show there true potential, I doubt anything else can be said.
Like I said before when you and I look at the power curves between those two motors we see two different things. When considering the stated application, Freiburger's challenger, there is a clear choice between those two motors. This isn't just my opinion it's the opinion of Steve Brule (of Westech who does this sort of thing for a living), Steve Dulcich ( Really needs no introduction here) and David Freiburger (ditto). Now, they don't always agree with each other but in this case the conclusion was instant and in unison, as soon as the graph pulled up. Even you said that this particular test was a bad example for the point you were trying to make. We can agree on that. So if you think your not getting anywhere trying to convince me that these to motors are an equal choice for Freiburger's challenger you could try contacting one of the three that did the test and convincing them that they unanimously came to the wrong conclusion. Who knows, maybe one of them will take it up as the subject for there next video.
I see what Freiburger, Richard Holden, you and others see, it doesn't take a rocket scientist to see that at every rpm point the 410 makes more torque and hp and view does have circumstances were it's applicable. But so does my view where you look from the hp perspective and see how much more rpm does engine B have to turn to make similar power as engine A now depending on the curves you might have to run a little more gear than you would with the larger engine.
In this case here this 376/410 you'd probably have to go one maybe two gear ratio deeper than what you'd put behind the 410 to be putting similar HP to the ground.
This convo has never been about Freiburger's challenger, but all he has to do if he wants similar power to the ground at any given mph is to run a little more gear than he would've with the 410.
Only if your not willing run deeper gears, but people do all the time, why there's stock stroke 340/360 doing 11's 10's etc.. there not running a set of 3.23.
I said it's a bad example because it's obviously hard for you to see the separate powerbands,
Again I never was talking about his Challenger you want to shift the convo that way.
I've said 100 times now I'm talking about pure performance potential between these engine.
Not necessarily in a drag only situation, could be stop light to stop light, 0-60, 1/8, 1/4 mile etc.. do these engines have similar potential that's it nothing more.
Nothing else, like mpg, idle, vacuum, streetability, price, anything like that.
Their way describing these engines potential is unfair to the viewer why, say you already have 367 built similar and now your like oh **** should I tear it apart go stroker those were some good gains, maybe but if they also explained you could get there with a little more gear now you might think that's the way to go. The guy can make a more informed decision, all I'm trying to get acrossed.
How many times does a similar scenario's come up here, with 318's, even with 340's/360's, 383 and 400's. People are always trying to push displacement, now I'm not saying displacement ain't a valid choice especially in a street car but generally if the guy is willing to run more gear he can get there too. I don't care which one he builds just give the guy the facts to make up his own mind.
The simulation I ran resulted in 3.71 gears for the 410 and 4.11 gears for the 367, and they were close. So I think you are right in this case
But after running the simulation where I moved the HP curve up 1000 RPM's and wasn't able to get close to the performance of the lower RPM 367, I think gears aren't enough and your theory doesn't bear out.
BTW, the 8HP simulation and 2.65M iterations was a bust, couldn't get close to the performance of the 727 setup. I wouldn't be surprised if my slip percentages and such make it an invalid test though, the simulator just isn't sophisticated enough to make it work. Plus the gear ratio's don't make it a slam dunk either, with a 4.71 first gear and a 4.11 rear gear, the result was the trans was in 1st for 0.000 seconds, or such a short time it can't be displayed in the output. More gear splits have to be an advantage, but I couldn't show it with the tools I have.
I think a lot of guys here are looking at this the wrong way.... Which engine would get better milage? The 410 with its torque and a higher gear.. easy choice.. the 367 doesn't make sense any way you look at it...
BUT...Since it's a glorious time and gas is only $1.98 a gallon... it's probably moot anyway.
Gears aren't gonna give more than the engines power will supply, why you can just throw 5.13 behind any old engine like a stock /6 and go 12's :) it will accelerate quicker until it runs out of hp which won't be too far.
I think 367 would love a 4 gear, cause it has a fairly flat hp peak.
Hard not to see. One is right above the other.
Is that how it's gonna be in cars ?
Does every car turn the same rpm at the same mph ?
If not do you think there might be some limitations reading the curves that way ?
To me that's an secondary issue, since were building performance engines first issue what potential do we have ? similar ? then go down your list of importants and yes the 410 probably comes on top of most peoples list, never said it wouldn't and have said could see it being better choice, But to say the this 410 has way more performance potential is wrong.
540 will make even more torque so why build anything less from 200+ hp ?
small block is easier to work on in the engine bay.... answered :)
You guys say that I have a minivan, how about proving it?
Probably gonna deny this is you?
BTW Dan... we are trying to have a serious conversation here.... there is even math in the thread.. no hijacking! :)
Have you said this to the others that started this, or just me? I won't say anything else but you should contact all that's involved. I was following this post and then the clowns have to join in. I'm silent
