acidspitstormchild
Got tired of laying around the house so went to tackle this loose coupler. Seemed easy enough looking at Steering Coupler Rebuild "How To"
. Removed the bolt at the end of the coupler. Started pulling the column but it just removes the shaft from the coupler. I wanted to remove as an assembly like the post above. Meaning the coupler comes off the box with the shaft.
Don’t want to hammer on it and damage the splines.
Thinking of re greasing the coupler while it’s still on the box and then inserting the shaft.
Tried to find info on here and service manual with no luck.
