Help with 340 timing cover oil seal please
gerahead
Glutton for Punishment
Maple Grove, MN
I am trying to get the 72 340 reassembled. I need to replace the front crankshaft seal in the timing cover. The seal that came with my engine gasket set is the wrong style. Mine is pressed in from the inside of the cover and the seal from the kit is pressed in from the outside. I can't seem to find the correct style needed for my application. Can someone please help with a source or part number for the seal that installs from the inside? The Mopar number on the seal is 3418494, if that helps. Thanks for your help!
I never heard of two different seals unless the Magnum has a different one? and Yes a LA seal taps in from the rear side of the cover.
install it with the same face pointing outward no matter if you go in from the front or the rear.
both of these styles use the same seal.
If I install it with the same face looking outward, there isn't a "face" that I can press against to tap it in. I would have to press against the slightly tapered edge of the seal. It seems to me that I would damage the seal housing by doing that?
You can use a seal driver or carefully tap it in with a soft faced hammer think like, one of those Craftsman where one side is plastic the other rubber OR use a block of wood etc. I think I always used a soft hammer before I had a seal driver set.
Pictures will greatly help here.
For sure, I was in the process of taking some and uploading them. This is the cover style that my engine has. The flat surface of the seal will need to bottom in this position.
These are pix of the seal that I took out. It has a nice, flat surface to drive it into position.
These are pix of the new seal. This one looks to be intended to be driven in from the outside. To keep the "wings" of the seal in the correct orientation, I would have to drive the seal from the thin edge, with no surface that can absorb the force of the installation. I don't see how I could do that without destroying the body of the seal?
For sure, I was in the process of taking some and uploading them. This is the cover style that my engine has. The flat surface of the seal will need to bottom in this position.View attachment 1716425071
View attachment 1716425073View attachment 1716425072
View attachment 1716425081View attachment 1716425082
Yeah, ok. You're just gonna have to get something and put between the seal and outer shell to drive on the inside of the front face. I use a small, flat faced brass punch. The block of wood is also another good idea and you can use that directly on the outer shell. Don't forget to put a thin coat of RTV around the outside of the shell. The red coating IS a sealer, but they always sit on the shelf and sealant dries completely out and is worthless.
Good job .
Like Gunny Highway said,,,,Improvise,,,learn to adapt !
I really like that piece of tubing and plate stock that NC builder uses .
Tommy
Good job .
Tommy
Awesome! Thanks NC Engine Builder!
Jim
Worked like a champ! I got a 3" coupler from the store and I was able to use the push plates from my Harbor Freight Ball Joint Service Kit on both ends of the seal and coax it in with a dead blow hammer. I tried using a large c-clamp first, but I couldn't get the pipe and seal to start square. I turned a 15 minute job into something a whole lot longer than that! Thanks to all who helped out!
Jim
