scudzuki
72 Dart Swinger project is still not charging the battery wheil running after a few attempted fixes. I reinstalled the Powermaster alternator that that came with the car after I bench tested it following directions I found on YouTube. 12V to the field connectors, spun it with a drill, 19V across the alt case and power stud. Another alt that came with the car only put out 15V tested the same way but that still passes AFAIK.
No charging when installed. Followed the same YT guy's directions for testing in the vehicle. Left the blue field wire connected to the field, connected the other field terminal from the alt to battery ground, started it, shot up to over 14V. Connected the green field wire to the alt, installed a new regulator, even added a ground from the reg case to another chassis ground point, but the battery is STILL draining while running (11.9-12V). Guess I can jumper the alt field terminals to the reg, rule out an issue with the wiring.
If any of you have some ideas I could try, I'm game.
Thanks.
Thanks.
