14v is respectableIt's in the ballpark, around 14V peak, when I checked last.
Obviously NOT charging the battery at 40A.
I needed switched batt V and that seemed like the best place to get it.
"Not charging the battery at 40A" where do you think 40 Amps are going because that's 40 Amps ABOVE what the car needs to run.
The alt meter would read 0 if the battery was not needing a charge and all the devices were being satisfied
IMHO you have a wiring disaster you need to take care of
For instance of your wiring has been alter to the point the loads are being pulled from the wrong side of the meter all the current is going through the meter
Your car for what you want.
