7875 + 5.9 + E85 + Megasquirt
Around 3k. 2-step kicks in around 2800rpm. I could probably build more boost but would have to stand on the 2 step for 30 seconds.
Have you made any timing manipulation tables once on the 2step? Yanking 15-20deg out really puts a lot of energy in the exhaust on my combo
I do as part of the 2-step params. I pull a lot of timing.
Next big upgrade. Preparing to have a cage installed. 12 point, mild steel.
I’m going too fast for just having lap belts as the only safety feature.
That looks great! Can’t wait to hear how it affects your handling and launches
Painting the roll cage. Another one of those “I’ll never do that again” projects.
In white primer.
Slowly putting this thing back together.
Painted the dash with the same spray can Rustoleum and put a matte clear on the top part to give it that factory non-glare finish. Turned out decent.
Put this Kilmat stuff all over the interior. It’s the poor boy version of Dynomat. Great stuff, easy to install but it def adds some weight.
Really want to see it but for some reason your pics didn't load.
