I needed to install a new distributor bushing in my 440/512 engine.
So, I "Home-Brewed" this tool to install the bushing.
It is made from a 1/2" x 10" carriage bolt. I put the bolt in my metal lathe and removed the square portion under the head. Then ground a flat on each side of the threaded end to hold the bolt with a wrench or vise grips while tightening the nut to install the bushing.
I had already installed the new bushing. This photo just shows how the bushing would be on the bolt for the installation.
I used a 1/2" flat washer and nut on the oil pump mounting. Just Tighten the nut until the bushing is fully seated and you are good to go.
