So should I enlarge the TSR first to richen up the transition (if so, how much if I’m already at a rather large .078”) and then also put in a 9.5PV (I know 10.5 was recommended, but a 9.5 I’d imagine will still get me in the ballpark to see if it helps the problem and like I said I have one handy already), and go from there?
I also don’t mean to continue to throw new stuff into the pot but I was also looking at annular boosters, something that came up in some google searches about getting fuel economy down, I currently have straight leg I’m pretty sure, I heard annulars get a stronger signal sooner meaning I can really lean out the idle/transition and still have a good transfer over to the mains without having a lean stumble, but I also heard if you do run annulars, you need to tweak everything because it changes a lot.
