What SWAY BAR to choose?
sin
Active Member
japan
Hello A-body guys. I'm looking to update the front sway bar on my '67 Dart.
I'm considering Hellwig or Hotchkis, but I don't know which part number is best for my car.
I'm not sure about the K-frame, but it's been replaced with a QA-1 UCA and LCA. Does anyone know if it's from '72 or '73?
I live in Japan, so returns and exchanges are a hassle, so I want to avoid any mistakes.
Per QA-1:
https://qa1.net/products/torsion-bar-lower-control-arm-kit-64-76-mopar-a-body/
Post up a picture of your K member.
The 1973-76 V8 K member offers what I think is the best design for motor mounts and sway bar mounting. The bar runs through the inside of the K member like so:
That sway bar is a semi-custom job I have used in several other cars. It is an 1 1/4" bar from a 1973-88 Chevy 1 ton 2wd truck.
Back on point. The 73-76 K member has the same dimensions as the earlier ones so It fits all A bodies from 1967 to 1976.
If you have the original K member, you are limited to a sway bar that bolts out in front of the K member.
Kメンバーの写真を投稿してください。
1973~76年式V8のKメンバーは、モーターマウントとスタビライザーバーの取り付けに最適な設計だと思います。スタビライザーバーはKメンバーの内側を以下のように貫通しています。
このスタビライザーバーはセミカスタムで、他の車にも何度か使用しています。1973~1988年式のシボレー1トン2WDトラックから取り外された1 1/4インチのバーです。
話を元に戻しましょう。73~76年のKメンバーは以前のものと寸法が同じなので、1967年から1976年までのすべてのAボディに適合します。
オリジナルの K メンバーをお持ちの場合は、K メンバーの前でボルトで固定するスタビライザー バーのみとなります。
Thanks for the reply.
Thanks for the reply. It's hard to see because it's not jacked up, but it looks like this.
Um... Something's wrong with that picture, but I can't put my finger on it
If you have the ‘67 K frame (or ‘68-72 for that matter) and you have QA1 LCA’s your only option is the Hotchkis sway bar for a 68-72 car.
The QA1 LCA’s have a sway bar tab position that’s basically the same as the OE 73+ sway bar tab location on the factory LCA’s. That make them incompatible with all the 67-72 sway bars that use the stock sway bar end link location. But you can’t use a 73+ sway bar with the 67-72 K frame because they don’t have the provision to pass the sway bar through the K like 73+ does.
The Hotchkis 67-72 sway bar though doesn’t use the factory 68-72 end link location. It basically uses the 73+ location. So you can use the Hotchkis 67-72 sway bar with the QA1 LCA’s. You will probably have to shorten the end links for the sway bar, but the tab location is compatible.
As far as I know, the QA1 sway bar only works with the QA1 K member, so that’s not an option with a stock K frame.
You're right, the QA-1 sway bar only fits the QA-1 K-frame. I only realized this after I bought it...
My car's sway bar goes through the K-frame, so how about something like Hellwig 55905?
Well if your current sway bar goes through the K frame, you do not have a ‘67 K-frame.
It sounds like you have a 73+ k frame, which would mean any 73+ sway bar would work. Can you post a picture of your K frame? From underneath and the engine mounts if you can. I was assuming you had a ‘67 K frame, but if your current sway bar works with the QA1 LCA’s and runs through the K it’s not a ‘67 K frame.
Oh geez, I didn’t realize these were pictures of your K frame! Sorry!
Yes, that a ‘73+ K frame you have. So yes, a Hellwig 55905 will fit that K frame and those QA1 LCA’s. That’s exactly what I run on my ‘74 Duster. I just shortened the end links to work with the QA1 LCA’s
Thank you, that was a big help. I'll buy it and try installing it.
There may be quite a lot.
Does anyone know? There was also a Mopar shop run by Kenji Okazaki, a former NHRA driver.
I bought my Dart at that shop.
I use the Hellwig w/ a 67-72 k and stock lower arms. Works fantastic. If you have questions...just call Hellwig. You will talk to a human that is very helpful and knowledgeable. Excellent product with great customer support. I have their rear bar on my car also.
