Ken Pevay
So I took out my 67 Barracuda today for a ride when we got to our dinner destination the car would not shut off so I popped the hood remembering that as a teenager if I pulled the wire for the ballest resistor, nope still kept running. Strange I thought, so I put on what I thought was a decent pair of rubber gloves and pulled the coil wire only to get Zapped! But it shut off. Afew other stopps on the way hjome it did shut off once with the key. But subsequent times I resorted to choking out the carberator much less shocking!! Anyways I pulled out the Ignition switch to replace it and found a cluster of wires taped together after I opened them up I found the cluster fu@#k showen in the photo, all soldered together. After further investigation looking at the wiring diagram the blue wire with tracer goes to one side of the ballast resistor, and the brown goes to the other side of the ballast resistor. Having thes all connected together effectively bypasses the ballest resister hence the reason it kept running when I pulled the wire?? It also looks like another wire used to be soldered ti this junction previously. I believe I need to separate these and reconnect the wires as they should be. Does anyone have any insite into why this may have been done? Will I have any other issues? Car has been running and working just fine for the 5 years I have owned it this was all done before I purchased it. I will be replacing the ignition switch as that should take car of my problem. Any thoughts or comments appreciated. Ken
