340 valve cover fill turn cap leaking oil
northeastmopar
Massachusetts
340 valve cover fill turn cap leaking oil at high rpm? Where can I get a new gasket that goes under that cap. I think mine is just all dried out and
Is there a baffle under the cap? My '72 did not, and the cap was always weeping. I scarfed a baffle in, no more weeping.
My pcv valve is good.
The PVC valve which is on the other cover seems to be fine. My understanding is if the ball inside rattles when you shake the valve, then it is OK.
Not always from my experience. They’re very cheap to replace. Buy a new length of hose while your at it. Kim
