904 - too much clearance in rear clutch
stoshzack
Member
Wake Forest,NC
Hi All -
I think I have learned that too little clearance in the rear (called “forward” I believe) clutch of a 904 will cause the vehicle to creep in neutral.
What does too much clearance do for that same rear clutch?
Thanks for any help
Hi All -
Thanks for any help
Too much clearance in rear clutch may cause the piston to travel too far and **** in the bore and cause clutch frictions to stay applied. Result would be no reverse or locked up trying to engage reverse
