Got a '68 Dart in the shop today. Customer was complaining the left/right turning radius was not equal. It didn't take but a short drive to confirm his issues. It turns fine to the right but not near as much to the left. When I put it on the lift I noticed the k-frame was a '73 up item.
I checked the steering box center to center turns. It was fine.
Customer didn't know if PO changed just the k- frame and left the '68 pitman arm, idler arm and center link. If I remember correctly, when using the '73 up k-frame you need to use the '73 pitman arm, center link and idler arm. Is this correct?
