Done all that. I’m just putting the intake back together after fixing a small vacuum leak. I also verified cam timing (intake valve opening) but it was degreed during assemblyForgive me if I asked, but have you verified your timing is correct? In other words verified your timing light is accurate? Also, have you verified TDC with a piston stop and checked that the balancer marks are in the correct location, that maybe the inertia ring hasn't slipped?
YepI’m sorry ,I missed that post .
I have never run the 68 4 sp cam but I have run many bigger cams . I would expect 12-14 @ idle and pushing 20 @ cruise . There will be variables like compression, timing , carb and exhaust system etc…. But under 10 just doesn’t seem right for that cam .
Have you tried another vacuum gauge?
