What vehicles had a HIPO 318?
MonkeyTrev
Knoxville, TN
This 318 engine popped up for sale near me for $140 bucks. I immediately noticed the windage tray and was intrigued. I never knew the 318 came with a windage tray as I never knew they made any performance packages for the 318s.
Is this something from the factory or added later on? I also notice the timing chain looks like a double roller, so probably a modified engine.
What years and vehicles would have included a factory windage tray in a 318? I was thinking maybe police cars?
I know the picture of the engine stamping is super blurry. I am trying to get a clearer image from the seller.
LA 318 "hi-po" ?? The only LA 318 that I'm aware of with any addition of performance parts was the 318 4bbl version found in Vans, Trucks, Ramchargers, Police Cars, and I even seen/drove one in a 2 door Volare. Obviously in the mid 80's and forward, roller cams and different heads were used.
P.S. - that picture is really kind of worthless... at least on my screen lol
I thought there was a 170 HP 318 available in the 74-75 Road Runners. I've never heard of one having a windage tray. Police cars did have double roller timing chains but I don't think they had windage trays either.
So sorry. It deleted the second picture. I added it back now.
Instead of chasing a Unicorn, get one of the factory 230 hp 9.2:1 cr engines.
'68 & '69 stock 318.
'85 to '91 stock 318 roller engines with the 302 closed chamber heads.
Now you will have a good basis to start with. Both 230 hp engines with 9.2:1 cr.
Single best upgrade is add a 4 barrel and dual exhaust.
(those 8.1 cr engines are way less desirable to try to build upon.)
Im trying to get the block numbers from the seller to see what year engine it is. I figure for 140 bucks whatever engine is worth that. I need a 318 for a barracuda project.
aww eeee .... yeah, ok. To me the only advantage in the 318's is those with roller cams vs those without. Also, the '68-69 will not have hardened seats. There are a lot of rabbit holes that can come up that can be costly to "correct". To me, hands down I'll start with the Magnum as it's easiest available, and really cheap. In the LA 318's, I'd like '85-91, but not because of 302 heads, but because of the roller cam.
I won't argue the early 'teeners were better than later versions in stock form, but just try to find one that doesn't need boring and pistons anyway- there goes any advantage. Same could be said for the later LA rollers; heck, they're going on forty years old now too. There's always the chance of finding a low-mile motor that you can get away with a dingleball hone and reuse the stock pistons, but your odds are better playing the Lotto. Your chances are much better with a 5.2 Magnum for that.
OP, the only "Hipo" LA 318s* I've ever personally seen were in mid-late '80s cop cars- I won't say they never made it into other vehicles, but I haven't seen one. But then again I live under a rock sometimes. The one and only cop 318 I've had apart did have a windage tray, though; although I honestly can't remember if it had a double roller timing chain.
*That's LAs- if you want to talk Poly 318s, yeah- they made some cool Hipo versions (but that's another story, and a whole different dialogue).
Mexico got a real HP 318.
270HP in late 60's as I recall in Mexico only.
Occasionally, I run a 78 318HP in our Aspen wagon. I
ran that combo at Mopar Nationals last weekend.
It has a big Thermoquad and 360 1.88/1.60 Valve heads
factory. It is currently rated by NHRA at 250HP.
It makes in the 400+HP range on the Dyno with a .380
camshaft in legal Stock specs.
The seller did say the engine came out of an aspen.
sure there was a e58 318? i thight it was a 360.
Both engines appear to have used the same "police" code.
From the Motales.com site:
The 1978 model year brought adapters for magnetic ignition timing measurements (timing lights still worked) and a second-generation Lean Burn system. New carburetors were half a pound lighter than the previous models; they used “solid fuel” operation, meaning that a stream of fuel was fed to the primary discharged nozzles and mixed with air there, allegedly to help with lean fuel-air mixtures. A new police four-barrel was introduced, given the phase-out of the big-block engines; this was the E48 package, with high performance “J” heads, dual-pickup distributors, windage trays, and double-row timing chains. Over time the engine would be upgraded as the police put it to the test, getting better seals and valve guides. The four-barrel setup made for a fast enough police car that many Diplomat/Gran Fury-driving officers thought they had a hot 360 under the hood. (The related 360 also had an E48 package, confusing matters somewhat).
1977 360 V8
Chrysler tested customer acceptance of a 318 in a Chrysler with the 1978 Cordoba S, a lower-cost Cordoba with the smaller engine; customers must have liked it, because the 318 was standard in the 1979 Cordobas. In addition, to counter the effects of primitive emissions controls, 1979 and later California and high-altitude cars had 318s with four-barrel carburetors.
Rapid changes for the old 318​
The 318’s block, cam, exhaust manifold, and rear main bearing cap were all changed to save weight for the 1980 model year. Then, starting in mid-1980 (calendar year), production moved to Mexico, making room for new four-cylinder engines at Trenton. It must have been a busy time for the engineers, especially given changes for the 1981 model year.
1981 four-barrel Chrysler 360 V8
First, the 1981 passenger cars could no longer have the 318’s bigger brother, the 360; instead, the 318 was available with the California four-barrel carburetor setup and a new intake. These changes increased output to a healthy 165 hp and 240 lb-ft of torque. Police cars could still have the 360 all the way to 1984; and the two-barrel 318 was still available.
For $140, I'd get over there and buy whatever it is.
That engine is old enough to have been modified lots of times.
Did '74 and '75 Road Runners both have dual exhaust? '75 was the first year for cats.
i may have the number incorrect... it was an off the cuff reply. let me look at my notes.
but 100% certainty there were 318's with windage trays, double roller chains and 4bbls
EDIT: E58 was always a 360-4bbl, but mopar being mopar... has all kinds of other numbers. for instance, E56 is another, different 360 4bbl offering. E46 was one of the 318 4bbl offerings, but again changed depending on the year. my mistake on the number switch-a-roo.
74?
The 1974 blocks are the same LA block, just had the lower compression pistons installed.
Here is a good factory bore 1974 318 block that I own, have a set of 1968 9.2:1 factory flat top pistons that I have slated to go in there. Also lately scored a set of 302 closed chamber heads, and have on hand the Melling 340 grind camshaft.
So yeah, this will be a simple sweet 318 when completed.
