fresh 727 will not kick down .wont kickdown at any speed.speed does not matter.bouchillon cable adjusted so lever on trans is full rearward at full throttle. carb is fully open. trans lever is all the way rearward and no kickdown.WTF else would cause this??tried another v.b. same thing.both v.b. have part throttle kickdown.ive messed with the kickdown cable adjustment for a few months and i give up. i thought bouchillon had the lever at the trans matched. im about to throw in the towel and get a mvb. what else could be causing this??
