Interest in another Group Buy: Molnar 7" Connecting rods for CAST crank
robsimmons
Slant 6 Drag Racer
Coxs Creek, KY
Please post here or PM me if you are interested in a set of aftermarket 7.005" connecting rods designed to fit a CAST crank.
There was a group buy several years ago, but they have been sold out for quite some time.
Minimum order of 7 sets of 6 individual rods each, total 42 rods.
Price as of today $787.25 per set. This could change if the order is not done soon so pricing would be confirmed at the time the order is ready to be placed.
Requires 50% non-refundable deposit.
1- Rob (1 or 2)
2- Steven
3- Lou (1 or 2)
4- Greg (1 or 2)
5- Matt
6- _____
7- _____
Specs will be:
H beam 7.005” long center to center
Fit stock 225 cast crank with 2.187” rod pin diameter
Fit stock .901” wrist pin diameter
Big end width .940” to fit cast crank rod pin width
Pin end width .980”
Weight approximately 605 grams
Molnar Proprietary 3/8” ARP2000 material bolts
Hi, I'm a new member and I would like to get in on the Molnar rod for cast crank buy. How do I do that? Kenny
Click on Rob's name, and select the "Send Direct Message" button in the pop-up, then start a private thread with Him....
Hey Kenny,
We are almost ready to pull the trigger on this next run of rods.
My main hang out is slantsix.org where a lot of the die-hard Slant 6ers are.
These rods should be paired with the right piston. Wiseco makes the right piston for this combination.
If you are serious and ready to send in the 50% deposit, I will add you to the list.
I'm ready. I'm planning on using the cast 2.2 Chrysler Sylvolite pistons that Summit sells. I think the ones with the dish. 88mm with a 15.5 cc dish.
Better check to see if those pistons can be used with floating piston pins. The Molner rods use floating pins, so the pistons must have pin retainer lock grooves. The stock 2.2 pistons for non turbo (flat top) are press fit pins. The stock 2.2 turbo pistons (dished) are floating pins.
I am planning on using the dished pistons. I calculated the compression and with a zero deck it gives me a 9.71 compression ratio. So that will work?
I'm about to "Hit Send" on this order of rods...
If anyone else wants a set, please let me know ASAP!
$400 NON-REFUNDABLE deposit.
It will take about 16-18 weeks before they will be shipped.
They have to have a minimum of seven (7) sets to make a batch, so get 'em now...
