Miles73
Member
finished putting in a front end rebuild kit (This Kit ) and it drove great for about 20 minutes, hit a pothole and dropped the whole passenger side suspension. after some investigation i found that where the torsion bar is held on the torsion bar is held on the torsion bar cross member had sheered. is there anything i can do to fix this apart from replacing the whole crossmember? it seems like i would have to pull the body to weld in a new one. i tried to just weld the spot where the torsion bar is held but it just sheered. i was thinking of reinforcing it with some quarter inch plate and welding the in. does anyone know if this would work? i am looking for a low cost solution because i am a broke college student and i don't want to just throw money at the problem.
