Stop in for a cup of coffee
speaking of 20 something...I'm sitting here getting energized after breakfast, phone rings. Friend that got his pacemaker installed is getting out tomorrow. Feels a little cool in here, walk past thermostat...68 degrees. WHAT!
what broke, gotta call, oh yeah, I replaced the filter and turned the furnace off at 6:15 this morning. only dropped five degrees in three hours. not bad. unfortunatelty, the wife and I are opposites with temps. the warmer it is, the more active she is. I can work fine in 55 degrees. needless to say, see was falling asleep at her desk. figured it out, flipped the switch and almost all is good. if you see a blob here, it's me melted cause she cranked the heat.
I got a kick out of going to the Speedway here in July and August when we got a lot of spectators from far away. I go to the bleachers with my jacket over my shoulder when it's close to 80 and the touristy spectators in their shorts and tank tops would giggle at me. "Bout 7:30 you gonna be wishin' you had your coats too." :lol:
How ya feeling Frank? You getting some stamina back? Are ya actually following the Docs direction?
Still waiting for 2nd procedure. More stents. Going to see my Doc shortly, will see if she will get the ball rolling. That and get on hip replacement list. 2.5 year waiting list..
WOW! that's great!
I replaced some wires in the furnace and used hi-temp wire from Home Depot. the others were not burned thru but had some crispy critter stuff going on with the insulation. Hmm, might be a good summer project.
Found a supplier for my limit switches, local guy gave me a connection
1984 Dodge D150 Regular Cab · Short Bed
Roller
Looks reasonable
Wow Frank that suks. Jodi is scheduled for a total hip replacement this month. From her first Doc visit on the hip to surgery day was less than sixty days.
Dr appt is done.
Shes going after the Dr that looked after my case while i was in hospital, 2nd angio should have been done by now. And wanted to get me onto narcotics for the hip pain, im still not ready to give in. Got a script for T3’s.
