Tire shop over torqued lug nuts (1969 Dart). Should I redo it?
I'm sorry, I linked the wrong dang one. It's this one. Trust me. This is something you can do. Just go really slow with light pressure. A very little bit at the time and check between cuts. Don't cut very long at all. All you're looking for is a clean, unifom seat. You're not trying to enlarge anything.
Thanks. :-)
Here's an image of one of the wheels. I seem to have got that working now. I don't know how easy it is to see the condition of the lug seats though.
Yeah, my mother is the original owner of this car. It's unmodified. It "only" has 158K on the original engine (225 Slant 6). I really would not be suprised if the lug nuts are from 1969.
Very likely. But they could still be in good shape were they not abused. No fault of yours.
Yeah, I can only imagine what was done to them over the years. I only started working on the car myself recently.
Am I right that 7/16-20 is the correct thread size for the lug nuts?
is it just me or do the nuts and wheel seats look galled
Seen that a bazillion times in the shop, it happens over time, even if they're not grossly over-torqued. It was common to have them on cars & trucks to come off dragging like a torque-prevailing nut, the wear & repeated torquing causes the nuts to become swedged, to the point they gall & pull threads coming off. Sometimes I'd grind the ends of the taper off, light lube the studs & run straight lugnuts on backwards, many of them worked OK after that. Otherwise, it turned into chasing/fixing threads &/or replacing stuff.
The taper dressing of the rim seat Rusty was talking about is very helpful here, old 60° seats in alum. rims need love too, they gall & get rough over time for sure.
People rarely think of it but it helps to lubricate the lug nut seats in the wheels too. It will not affect how they lock down when torqued.
Affirmative, nothing too slippery, but it can save them from the kind of galling/damage pic'd above. Al-U-minimum seats with the wide taper lugnuts can cause torque sticks/clickers to stop before the studs are properly loaded, and yes they can & will loosen if that happens.
But then, that's why all lug nuts are "supposed" to be rechecked periodically. Hardly anyone does it, though.
Interesting. I've now learned what it means for something to be galled. That explains the appearance of the lug nuts and wheels a lot. I guess I should check the lug studs too, but my recollection is that they looked okay.
So lubricating the lug nut seats won't affect the torque setting (have the lug nuts end up being overtorque)? I've seen people say if you lube the lug studs themselves you will end up effectibely overtorquing. If that's not an issue, is there a specific lube people would recommend?
Any kind of light penetrating spray lube, I've been using Sta-bil Fogging oil here around the homestead for that sort of thing, just not super-slippery stuff like Wurth HHS-K or the like (Zep 2000(?) ), they set up & are capable of causing the overtorque You're concerned about.
