[WANTED] 90 Degree oil filter adapter for 5.9 Magnum
abuchakl
Member
Mukwonago, WI
Rating - 0%
0   0   0
Looking for a 90 degree oil filter adapter for a 5.9 Magum.
It is going in an early A-body with TTI headers.
I appreciate the help and I'm located in SE Wisconsin if anyone has anything in the area.
I'm not trying to fill up your want ad with unnecessary posts, but I think you're going to run into issues trying to run a 90* adapter on a Magnum. The 90* adapter was designed for the LA series, and the Magnums have slightly different machining in the filter area- the heights of the two sealing/gasketed areas are not the same between the two engine families. Even the flat filter plates are different between the two. Using the 90 on a Magnum can result in leakage onto your headers or worse. There may be a workaround that I'm not aware of...
If header clearance is your primary concern, then consider using a shorter oil filter- usually a Wix 51085 will clear the headers, but in extreme cases you may need to go to a Wix 51335- the darn thing looks like a hockey puck, but usually fits where nothing else will.
I usually like to run as big of a filter as I can, but sometimes you have to make concessions and just change the filter more often.
View attachment 1716485985View attachment 1716485989
I appreciate the info. I did consider a smaller filter but on the early A TTI headers I don't think I even have 2" of clearance.
Thanks Rob, the plate that mounts to the block is different for sure. It leaked the the Exxon VD. I am not sure about any other differences.
Does a 340 90 degree interchange? If so I have one in Michigan. Shipping would be cheap.
@4spdragtop Steve has experience with this too. Maybe he will chime in and tell you some details. I tagged him.
You need part # 2463661. It's the one on the right in the pic, and is a TRUE 90 degree adapter. The later one's like on the left in the pic are not 90 degrees and will put the oil filter into the frame rail in an Early A body.
Pic of that adapter on my 273, with Dougs D453's just hanging on it for reference. I will be using D450's in my 65 Barracuda.
Mods, just tryin to give him info he needs. I know y'all are lookin at the comments like....
