Aftermarket tach in rally cluster 67-71
This one come out of one almost just like that
Only thing I see differently is auto meter changed over from the knob in the 60s and in the 70s went to a smoother knob and kept the smoother knob until it went flush mount
Looks like a nice clean install. I'm thinking about doing this as I may have to pull the cluster to change my dash pad. I should have done it last year when the whole dash was out :BangHead: (the idea hadn't even crossed my mind). Do you know what the id of the tach plug is? I assume the tach face is slightly larger. I was thinking about the Autometer 3780 (if it takes the 3 3/4" tach) as it goes to 8000 rpm. Thanks.
Excellent work man, they both look great and the visibility is a huge improvement over the stock tach which I was disappointed in after installing. If I get another rally dash car I’m putting the 8k auto meter in.
That great work looks good .Am thinking of doing this but have to try to find the right tack.
Where cane some one find one of them tack.
Yeah me too. I don’t really want an 8k or 10k tach when redline is 5500. If you are looking for something stock like there are slim pickings. There are a couple 6k tachs and if you want 6k at 1 or 2 o’clock good luck.
Thanks i will .I think i have a few old tack here in my stuff just have to find them. How about the Sun tack is that close to fit
One question… I just pulled the cluster and removed the blank housing. The od of the blank is about 3 1/8". Is that the diameter of the Autometer 3 3/4” tach face? I realize there is a blank gap around the circumference of the face. Also, the id of the bezel attached to the front is only 2 1/2". I'm assuming it cuts off the hash marks a bit. I just want to make sure I didn't miss something and order the wrong tach.
i have a few question did you use a vacume tack or electric ,did you have to cut any thing like the housing and the black part that you see when there no tack and last one how do you get the tack to stay in place do you use glue .thanks for all your info it great stuff
Just a note and to answer my previous questions. I just bought an Autometer 3996 3 3/8” in dash tach. The od of the Autometer tach face (hash marks) is almost 1/2” larger than the opening in the front bezel. I might try trimming the front bezel lip off. The Autometer plastic cup that holds the tach mechanism is 3/8” larger od than the id of the dummy plug off the cluster but fits in the hole. I’ll have to fabricate a holder of some sort. I see others have done this.
