Elmo65
What kind would you use? I thought maybe I might use brass. Would that be a good idea? This is for a slant six. The three that hold the two manifolds together. And maybe studs and nuts to hold the manifolds to the head.
Same here. And if ARP or someone else makes um new over 50 year old onesI would use steel with antiseize on the three bolts. , brass is soft.
Chrysler had it right. Why would you use anything else? The only "upgrade" I would suggest is the Remflex gasket kit and grade 8 hardware. I also use high temp red RTV on the bolt threads so I will at least have a fighting chance of getting them out next time.What kind would you use? I thought maybe I might use brass. Would that be a good idea? This is for a slant six. The three that hold the two manifolds together. And maybe studs and nuts to hold the manifolds to the head.
AgreedRemflex gasket
Likely not. Penetrating oil and heat.Thank you for your replies. I just hope I get the old one off without breaking them.
I have used a diamond bit on a dremel to start a centered depressed spot to center the drill bit,I've had to send a few /6 manifolds off to the laser bolt extractor guy at the local diesel shop. No matter how hard I tried I drilled them off center and didn't want to be into the parent cast iron of the manifold. No matter what that bit will walk along the twist line left behind by a busted bolt. The only time "not" is if they break off "proud" where they can be dressed flat before the center punch
