340six
King Of Bling
What ys use or is there no Secret Sause? I have some that are really stuck on.
I have to soak the carb to try and soften the glued on rear metering block.Scotch Brite Roloc Bristle disc is made for gasket removal . Use light pressure.
Spray some Seafoam Deep Creep all around the joints where the gaskets are. Let it sit for a few days. Keep sprayin it. It'll come apart.This is all assuming that you can get the carb apart.
I've got a 850 dp that a hammer can't get the bowls off of, let alone disassemble anything else.
The bowl in front right off, metering plate too. Almost to easy. Rear bowl right off. Metering block no dice. Score is:This is all assuming that you can get the carb apart.
Edit : bolted to an intake, neither a soft hammer, nor a hard hammer and aluminum drift would remove either bowl. I guess a sledge hammer is next.
Mineral Oil like you put on a cutting board? Or Mineral Sprits ( paint thinner) the Solvent?Soak the partsl in mineral oil for 24 hours and work the off junk with a plastic scraper. That way the is no gouging and chunks taken off the mating surfaces.
maybe heat it?This is all assuming that you can get the carb apart.
