Looks very similar to the 92 Jeep Cherokee column I’m going to put in my Duster. Mine is a floor shift column though.
Fiddly stuff can eat up twice or more time than the time a body repair would take easily! I'm in the details on mine now tops going on and engine is going in againForgot to mention this column has the metal mounting brace spot welded to the tube. To gain sufficient height did not use those plastic spacer things. Did have to trim the brace so the AC vent would fit. It’s all those little things that takes time
Mine has the multi-function switch as well but I do plan on using it for my wipers since I’ll be doing a custom instrument panel as well as using a wiper motor with the intermittent wiper feature.Does yours have the multifunction or just turn signals?
I don’t need the wiper function on mine as I’m using the stock dash mounted variable speed wiper switch
Well, the wife of the local guy who had given me a down payment on all the stroker parts contacted me a couple days ago to tell me her husband had suddenly passed away and was there any way I could return the down payment. Absolutely not a problem!Another change of plans (sort of). A local guy heard about my stroker kit and made a nice offer on the kit and 318 that the stroker was destined first and gave me a down payment on it.
Bill is a friend. He has the T-shirts!!!Here’s a few more pics of panel wagons that popped up on fb yesterday. The last pic is the post of the guy who had the black one.
Am not sure if I’ll get to it today as we are going to the vet with a very sick dog but if possible The plan of the day is to get both carpet hold downs installed.
Hello DartmanNext thing to add to the firewall is the driver’s side fresh air vent. I bought one with a working door hinge as so many are broken - the one originally on the car was missing the door all together. The vent needed to be cleaned, old hard foam Seal removed, door stripped of runny paint, painted and maybe even a quick coat of black on the vent. After removing the old foam seal and hand sanding the vent as well as the door, it got a couple light coats of satin black paint, new foam on the inside of the door and new foam seal on top. The seals were another super item from DMT - no they’re not sponsoring me - they’ve got great products that actually work and fit as they should. Vent Is now ready to install tomorrow!
Hi SteveHello Dartman
Is there a proceedure to secure the J hooks or is there something I'm Missing?
Many thanks if you can help!
Thank you,
Steve
