So while I’m rebuilding the fuel system on my Duster I want to run the engine to see if I can at least start it and the power steering works. I rigged up an auxiliary motorcycle tank that holds about 2 cups of gas with a gravity feed to the carb fuel line. If I give the carb a small squirt of starter fluid the engine starts right up, but will die in about 5-10 seconds unless I manually move the throttle linkage. BUT when I move the linkage, even a tiny bit, pretty quickly (a few seconds) the engine will backfire through the carb with a scary flame. It’s even more scary since I'm leaning over the engine with my hand on the throttle linkage. The guy I bought it from drove it onto the roll-back for transport so the timing can’t be that far off, right? While it’s running the engine sounds smooth so I don’t think it’s missing. Next steps? I’m keeping a fire extinguisher next to me with the pin removed while I’m figuring this out. Carb is a Edelbrock 1405 600cfm four barrel with a manual choke.
I should also mention the vacuum advance on my distributor isn’t connected, but that shouldn’t matter at idle, right?
