Early "A" driveshaft safety loop
66340SEDAN
FABO Member #3649
Minnesota
What are you early "A" guy's using for a drive shaft safety loop? Anyone try this one, I found it on ebay, not sure if the hole will line up on the trans crossmember. Thanks, Keith.
http://cgi.ebay.com/ebaymotors/A-Bo...011QQitemZ320223832544QQrdZ1QQsspagenameZWDVW
I have one of those I am going to use on my 64. I moscked it up and it seems to fit okay but I won't know until I gat the driveshaft made. I am going to weld it to the crossmember.
Interesting. I was thinking of making my own. Is that thing aluminum. I sure hope not. Or is it galvanized. You got a link to the ebag listing? It looks adjustable too.
Cut that puppy in half, rotate it 180 degrees, and mount it to your pinion snubber mount. Now it looks like a better rear driveshaft safety hoop!
I perfer the floorpan mounted hoops. The one that hangs off of the crossmember just looks like a harmonic vibration waiting to happen on a highway driven car.... :shaking2:
I ran one on my 67 Dart with no problems. Not a himt of vibration. It's made of steel and plenty beefy
I used a bolt in from Summit on my 62 Valiant, the floor board type, I also beefed up where it mounted too.
T6061? Does that meet nhra/ihra standards in case that's an issue??
