mopar head
Time for a new clutch kit. To all you 4spd guys, what is the ticket these days, without breaking the bank? The current kit came from napa, 3 arm borg-beck style. Brutal pedal effort, but would defenitly grab. The downside is in short order it put 3 hot spots on the flywheel. Is this a fluke or could this be caused by a little oil contamination? I neglected to purchess/if available?, the sheetmetal shield cover, Anybody reproducing these? If hot spots are the norm, with 3 arms, I dont want to go through this frequently. So if you been running centerforce dual friction, or mcleod, ram, or any other manufacture, what are you opinions or suggestions on a clutch kit? Also is there a limit on how many times you can grind/surface, a flywheel? thanks in advance:read2:
