I would certainly NOT go backwards on a cam!
I wish that Hot Rod mag article had gone a head and tested the cam (or one that didn't require machining) with out the high dollar heads and rocker assemblies.
I used to know what the diff was between the 300 and 380 HP versions of that crate motor. Were the pistons different?
