I refuse to hang 750 + pounds off any intake. Screw that , I will use my chain
nice tip! Not often someone lets out one of their little trade secrets around here.Heat the intake with a torch while the motors' hanging.
That's how tunnel rams are made
750 lbs? The only mopar engine that weighs anywhere near 750 lbs that's a possibility for these cars is a 426 street hemi. 273/318/340's are ~525 lbs, 360's are listed at 550 lbs, 361-400's are 620 lbs, 413-440's are 670lbs. And a 426 street hemi is ~765 lbs.
I pull em fully loaded , transmissions and all, not to mention the tugging and pulling I do. I will always use a chain.
that's on there wrong - holes go front to back - they work like a charm! it ain't nuthin' but a thingIs it a bad idea to lift the motor using a carburetor plate with an aluminum intake?View attachment 1715007541
