1976 dart sport dragcar
Jerry gray
Zuni va.
Hey guys/gals. I have been working on a dart sport.bought February 2018.no motor.has fiberglass front fenders and hood decklid and bumpers. rollbar was in the car.spring boxes and subframe connectors. I went to work. I have a few pictures of the car as I went along.put Dana 60 with ladder bars roll bar to 12 pt cage.i mocked it all up.had a guy come and tig it all.Hot worxs of Portsmouth VA.the guy can weld. I fixed the rear quarters.they had been cut off . spent some time working on this car last year.put a 340 with 4" callies crank eagle H beam rods wiseco pistons, roller cam w2 heads Holley strip dominator,850 hp 727 turbo action9" converter, shifter and valve body.456 gear ratio.went 6:50@105 twice and broke the head.67 cudaman and yellow rose have come.threw with a head each.hope to have it back together soon
Ok, i will give up now. There isnt a hope in hell i will get my 76 to look as great as that. Good job!
NICE, WHAT PAINT CODE IS THAT ?
Yes, it did look real low in the first picture. That makes a lot of difference, almost the same height as the lower potion of the dash. Nice Work!
I'm diggin' it...... perfect decor for the race office. When do we get to see more?
Doin up a 74 Dart Sport also. Can you tell me the Headers you plan on using with the W2 Heads?
Looks like they were already on the Car for previous Motor. Curious if these will fit the W2 heads though. Were W2s on the Car previously?
I bought these especially for w2heads for the dart they have been in the car, broke the motor and took it back out. A plastic bag got stuck to the bottom of the header and left a brown spot on it.wind blew it under the car .they fit good I'm the car. Alitte closer to the transmission than I like but they fit
Header wise, after TTI, you only have Hedman.
They have a verity of tube sizes.
The headmans are nice my friend Dan has them on his demon.lots of room around the transmission.he had to cut a hole in the inner fenders. I didn't want to cut the holes.they are probably better than the tti.cost more also
