I bookmarked your post for later if it makes ya feel better. LOL
I don't even know what kind of car, but we stored one in a freezer truck for someone when I worked at the cold storage. Not sure what the purpose was. That had to be around 1990. Was in there a month or more IIRC. I heard it wouldn't start when they got it out..There were some tests that they did for Jeeps and trucks that were "confidential" and we were not allowed to talk about in public... The winter cold testing was insane!!!! (but I can't talk about that...)
No more cheap 360s around here. The la’s are all gone.Hell yeah... Put a 4 bbl on that sucker... A good dual plane intake with a 600 vacuum secondary carb will run nicely....
360's were unappreciated for many years because they were "smog" motors... but if you build them to the same specs as the old 68 - 71 340's they run like raped apes....
Throw a set of 2.02" intakes on them and a nice cam and 4 bbl and they will run with a 340 all day long, if not beat it....
You can pick up an old 360 2 bbl engine real cheap... Now slap in a stock 340 cam (268/272 duration and .429"/.444" lift) or slightly larger, 2.02" intake valves, and a good dual plane intake and 4 bbl on them and you have a very affordable engine that will run great.... All 360's came with 1.88" intake valves...
Ok, I read that now. Thanks for waiting.Mechanical fans are more efficient than electric ones...
But with the A/C on you need some extra air flow, that's why they put the electric fan in also...
I worked in climate control for 3 years and participated in some of the testing... They do alot of testing on the "cooling package" (radiator and condensor with fans, shrouds, and seals)...
Part of the testing is to pull 5000 pound trailers through Death Valley with the A/C cranked... Death Valley is so hard on cooling systems they have signs posted there to turn off your A/C so your engine doesn't overheat... Our testing was to put them through worst case, so they pulled max trailer loads with the A/C cranked to be sure that the engines did not overheat and the customer can remain comfortable with the A/C on...
Another test that they do is to park the car/truck with the front end one foot from a wall at the Arizona proving grounds and let it idle for 30 minutes or more... This makes sure that the fan, shroud, and front end seals do their job to make sure the air goes through the radiator and condensor and not around it... It's more severe than idling in traffic at a stop light... You don't get the ram air through the front end like when the car is moving and is the most severe test for idling...
People don't realize how much testing they do to make sure everything works properly...
However if someone modifies the parts from stock, and it overheats, they won't warranty it.... Like if someone puts an aftermarket grille on the car or truck and it overheats, they are on their own... If their aftermarket grill has more air restriction, then it can overheat easier... People don't think of that when they customize their cars... One of the challenges is to have enough opening in the grille to get more airflow through the condensor and radiator...
That's why they reduced the number of openings on the Grand Cherokee around 94 - 95... The old grille had 8 openings and the 'new and improved" grille had 7 openings, but they were a little larger.... That increased the front end airflow by 10% which helped lower the high side pressure through the A/C system....
They also changed the condensor tubes from round to star shaped... The star shaped tube had more surface area, which gave it more ability to transfer heat better...
I will take the 360, clean it up and hope the thermoquad works as expected. New timing chain and thats about it. I should put the 340 intake i have on it. Wont matter though. It will be better than whats in it now. 87 hp factory, its probably 70.2 in its worn out state. And i sold it, to offset the budget 360 swap.
Sounds like a perfect plan!Thinking of taking the Demon for groceries. Small town grocery store I like about 15 miles away. Beautiful day so far. Sun is very warm, partly cloudy, looking for 70 today.
Grocery getter. Why not.Thinking of taking the Demon for groceries. Small town grocery store I like about 15 miles away. Beautiful day so far. Sun is very warm, partly cloudy, looking for 70 today.
Maybe..Was there a body in the trunk?
