And no, you made no mention of oil carrying away heat from the rod/main brgs, another lie.
Oh dear
I pointed out that oil carries the heat away when I was talking about pressurized oil feeds to needle roller lifers earlier on.. So yes, I obviously understand that function of oiling..
See the quote of your post in my previous post above ? It quotes what oil does, it does not mention anything about the rod/ mains. That's why I specifically quoted it that way..Get the drift?
You went off the edge of the map by yourself on that one.
If you bothered to get your head out of your *** and comprehend the posts then:
1. You wouldn't look like a complete twat
2. You wouldn't be making the false claim that I'm a liar.
I'm just pointing out how the oil is being delivered to the bearings, one internally under full mains pressure, one that is not, that's it, nothing else.The picture shows it clearly. I don't care what the bearing thinks, because I'm not specifically talking about that.
Your the one who's waffling on all over the shop with, heat dispersion, wedges etc, accusing people of being liars and generally losing your **** over it..
Time to move on I think..
