I pulled my 408 stroker’s six pack intake off to fix an oil leak, engine has about 3,000 miles. I noticed what I’m assuming is carbon fouling on every valve, see photos, please.
I have have been fighting rich idle and cruising AFR since installing the six pack. I am making headway and have made AFR improvements and will continue to do so. Is it worth trying to clean this fouling off the valves? If so, any suggestions on how other than removing then disassembling the heads?
Separate note, I have Hylift Johnson lifters made by Topline Automotive in Michigan. I’ve had a ticking noise since building the motor, all RPMs, mildly worse on start-up. No exhaust leaks, checked everywhere but changed the header flange and collector gaskets anyway. With the valve train still on the heads I cannot collapse any of the lifters when pushing on the rockers. Since the intake is off, any suggestions on checking the lifters for a bad one? Pull them all and try to collapse them another way?
Thanks for any suggestions.
