bit the bullet and bought a $30 buck heater core for $90 at a local chain store. Hey, it was in stock and the car wasnt moving with that leak. Looked into looping the line but that was gonna cut a good line and just make more work when I got the new core in the mail, so...Job can be done in about 40 minutes on a 02, really!
1.drain coolant or whats left.
2. remove 3 rear seat belt anchors from the passenger side 2 19mm on the botton, 14mm one on top.
3. pop the 2 panels off, (they just rip out from friction clips) the front panel toward the door has a bunch of screws under the speaker grill that just pulls out. pull them back and youll see the heater core pipes.
4. remove pipe clamp screw, and loosen the 3 nuts under the car that hold the plenum right by the A/C block and the 2 10mm bolts that hold the plenum to the body.
5. break heater core flange that goes under the 4 retaining clips, or else youll break the plenum clips and you are replacing the core anyway. Pull it out and remove the hoses. Its that easy. The new one will most likely have a styrofoam wrap around the edges, keep it on. Itll make the insertion very tight but I think it keeps the rattle out. Mine was literally split on 5 of the 7 copper loops at the end. The splits were like 3mm wide, the leak would suck the radiator empty in about 10 seconds!
