So is it the Kerf from the cutting blade that changes the fulcrum point to 1.6 ?? And,would you be offering your services as I don't have the smarts or tools to do this !!rayer:
I don't know what thickness of the blade that Aaron used to do this slice, but the one I used was .102". That ended up with about a .104" cut, which was just right. Manhattan Supply (MAS) has those blades. They're about $85.00 apiece, but the have free next-day-air shipping, which is nice.
But there's no need for 1.6:1 rockers if you can use a cam with a lot of duration; the problem comes with turbocharged engines wherein you CANNOT use a lot of duration, but want .500"-lift. Can't get a cam ground with short duration and that much lift; the lifter edge will bite into the cam lobe (on such a steep lift ramp,) and destroy the cam in short order. Hi-ratio rockers is the only answer...
If your engine is normally aspirated, I think you can get a cam ground with plenty of lift (with stock rockers,) since the duration is so much more. No problem.
Save your money...
