[Found!] 10 inch front brake drum for 66 Formula S
They are available new, at Rock Auto and elsewhere. Just an FYI, before removeing the old drum from the hub, make sure you remove the swedging from the studs. If you try to remove the studs/drums without doing so, you will probably ruin the holes in the hub.
may have a set ill ck mon
I was not aware that they would come apart.
I'll look into that.
Thanks.
I have found new drums that will fit and work but they're different from the original style.
The originals have a groove around the outer edge that the backing plate fits into.
The replacements are notched to ride inside the backing plate.
I think I will go with used original if a member has some to sell.
Pics
one looks oem
the other new replacement
also have loaded backing plates
new shoes and hardware
one looks oem
Great pictures, thanks.
In the 3rd picture the one on the left is OEM, that's what I'm looking for.
Are you able to sell that drum or does it all have to go as a package?
