10 sec 6.1 ?
DODGESTRIKE
mex
ok i know i asked about the turbos on a 360 before but asking doesnt hurt:read2:
can this be done ? no stroker , no nitrous , no blower , no turbo
stock stroke 6.1 , carbureted , pump gas , 10sec
1973 duster 3340lbs , slicks ,904 trans
The only issue is making the power, so, what parts are needed for the 6.1 HEMI to make that power?
Cams are limited, head porting would be the next issue.
Then it's gear ratio, a good racing converter, hooking it all up to the pavement.
10 flat? I don't think so. In the 10's, I don't know.
thats what im asking , what parts are needed
head porting is done by frank racing i think
cams i dont find many , does anyone make customgrinds for the 6.1?
gear , converter is decided by the cam
i dont think so either , im in the search for high.mid 10s
Lots of custom cams can be made for ya...frank racing, power ported performance, inertia motorsports, HHP, comp cams, indy etc... Check out lxforums.com for some buildup specs or builders.
ill take a look at that , do you know where can i get the 392 crate hemi intake manifold ? it looks a lot better than xv intake:toothy10:
For a carb application Indy makes one as well. The MP carb version intake sticks way up, through the hood. The stock efi manifold's pop up on Ebay or lxforums regularly
It can be done for sure i rekon...
Heads flow pretty well out of the box.
Say you need 530 hp to do a 10 with that weight.
Standard it makes what, 425 hp?
I rekon you can find another 100 hp easy with
after market air filter,computer to tune for optimum results,
an a bigger cam, an maybe a bigger throttle body!
I just realised now you said carb, argh..
Doesnt matter,i still think it can be done!
For sure.
Dont make me start finding you the parts lol.
Remember too,that this engine will weigh less than your
conventional 318,340,360....
I have a custom grind cam. They are no big deal, you just need to know what spec's you want. As for 10's with no power adder? Not likely unless the car weighed in at about 2000 pounds.
Reportedly a few Drag Pack Challengers have hit those times with a 6.1, although they're a bit lighter than your target weight.
how do you plan on getting spark?
6.1's are kinda pricey, for the intitial $$ you could spay a almost stock LA into the 10's
Well the 392 makes what, 525 HP? That's enough to put you into the tens in a 3100 pound car with a good chassis. I don't see why that can't be done with a 6.1. The heads are easily ported to 300 cfm's of flow at .600 lift and that would support 600 HP with the rest of the appropriate package.
You need to ask around and find some people that are running those numbers and see what they are using so you can get an idea of what works and what doesn't.
I read about a guy in Mopar Enthusiast that has a GTX, dropped a 5.7 hemi, and is running 13.321 @ 102.???, all stock motor. How much does that car way, 3500 plus or minus a few? That aint bad in my book.
I know of quite a few stock block head, cam, ported intake manifold LX running high 11's that are in the 4400 lb range so the same settup in a 3000 lb A body should get it done. The rest of the chassis will have to be up to the task but considering most of the LX's running those times are running a 3000 RPM stall and most are stock 308 gears. If you went bigger on the stall with an A body and optimized your gears then you could cam up a little and maybe run a mid 10. For instance,,, alot of the LX's in the 11's are running a 218/222 duration on a 112 LSA on a stock block you have to limit your cam advance to about 114 ICL for enough valve to piston so you don't want to go any bigger on the intake duration because you loose too much bottom end. But with a lighter car and a high stall like 4K or more converter you could run something like a 226/230 duration and just retard the cam enough to clear the intake valve with the piston which should be about 118 ICL. This cam would be a dog in a 4400 lb LX with a 3K stall but would likley work well in a 3K pound car with a 4K+ converter. Saying the LX's with the 218/222 duration cam, heads and ported intake average 450-460 RWHP thru a full exhaust with cats the bigger cam would likley make 480 with everything being equal then you can pickup some more without cats or even more with an open exhaust. I say 10.5 is easily within reach. It would just have to be done right.
Guys, sorry but the answer is real simple....yes, easilly.
10 second time slips in an a body powered by a 6.1? Why not? 3300 pound 318 cars run in the 10's!
edit-Bob's car actually weighed 3170 pounds
Bob Mazzolini
2000 Chrysler Sebring
NHRA GT/HA
1985 Chrysler 318
Compression 8.9
Quadrajet Carb
360 Swirlport Heads
Holley Annilator Ignition
Weight 3170
Best ET 10.23
Best Speed 130
Best 60ft. 1.33
Tire Size 12.2 W
5.87 Rear End Gear
there are a few people that have a 6.1L in their charger,magnum, or 300c that are running a setup with no nitrous, turbo/super charger that are in 10 second range. keep in mind those cars are 4000Lbs but i dont know if they are stroked. check out the LX forums
A big part of why:
5.7L Hemi Flow Numbers
Stock 5.7L HEMI Heads
Lift Intake Exhaust 0.100 74 52 0.200 144 111 0.300 210 146 0.400 251 160 0.500 265 164 0.600 267 166 Ported 5.7L HEMI Heads
Lift Intake Exhaust 0.100 64 47 0.200 134 104 0.300 210 145 0.400 266 170 0.500 300 194 0.600 320 204
6.1L Hemi Flow Numbers
Stock 6.1L HEMI HeadsLift Intake Exhaust 0.100 85 42 0.200 174 111 0.300 246 160 0.400 290 179 0.500 310 179 0.600 318 179 Ported 6.1L HEMI Heads
Lift Intake Exhaust 0.100 92 43 0.200 173 114 0.300 250 168 0.400 311 202 0.500 348 223 0.600 368 224
http://www.thehemi.com/
Bob Mazzolini
NHRA GT/HA
1985 Chrysler 318
Compression 8.9
Quadrajet Carb
360 Swirlport Heads
Weight 3170
Best ET 10.23
Best Speed 130
Best 60ft. 1.33
Tire Size 12.2 W
5.87 Rear End Gear
So your telling me your 318 is going that fast,non stroked,
naturally aspirated?
Big gears,must turn some crazy rpm....
Not my car. Bob Mazzolini's.
Bob's shop is located in Riverside California. He has been building and racing Mopars for a long time.
and yes, that engine is an NHRA legal Super Stock GT/HA Class 318 w/360 heads and low comp! He has to run stock bore and stroke and factory comp, heads and carb...that's the nutshell of the rules. Many factory parts and many aftermarket additions (crank,rods,pisons,valves,intake,ported 360heads,headers)
That car is basically a pro stock car. the 6.1 will make more power so you won't require the extreme chassis to run the number.
I'm pretty confident that a stock block 6.1 in a car that was a daily or weekend driver could get in the 10's in an A body. I mean, heck theres a stock block 5.7 quad cab 05 Ram that runs 12.7x on motor at 5000 lbs race weight and thats his daily driver just bolt on the DR's and go run mid 12's with the quad cab.
this thread has me thinking real hard, those 6.1heads flow like crazy and the blocks seams very beafy in the right places compared to an old LA motor
check out the April Mopar Actions article on just that. This guy got a 10.62 @131. He runs a belle S/C @20 psi on a bone stock 6.1. It's good for 776 RWHP. He then tried to bump it to 22 psi and made 800, but blew the bottom end out of it.
Moparaction.com
Moparaction.com
Adam knew it would not last long at that high of output, but with what he had planned, he decided to see what he could get out of a stock block before it blows. He is a regular over on LXF.
Either way that is pretty impressive for the motor to make that kind of power on the short block OEM pieces.
