10 years old Die hard Gold
Electrical and Ignition
  1. cchrishefish
    cchrishefish Well-Known Member
    466
    59
    Oct 22, 2009
    Syracuse, NY
    Local Time:
    9:45 PM
    Ok, my battery is a group 24 F Die hard Gold battery which has had a pretty long life. This is the first year the battery lost its charge while garaged during a very cold Upstate NY winter. I have found a really great deal from Pep Boys for a Bosch AGM battery, however, I am thinking, if Die Hard has been such a good battery, why not buy another one. The Die hard is not a AGM. Also, I can get a really good deal on a Interstate battery, also not a AGM. I will not be considering an Optima battery, too much money for me. So which one would you choose?
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,957
    871
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:45 PM
    10 years on any battery is amazing. I was told that die hard batteries had a patented bottom that collected the misc gunk that acumulates prolonging it's life from shorted cells. Like they said in High School Musical, stick with what you know. (Teenaged daughters 5 years ago!)
  3. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    50,183
    16909
    Jun 7, 2010
    Georgia
    Local Time:
    9:45 PM
    Want to save the Die Hard? Here's how. If you want to be all greenie about it, dump the electrolyte in something and dispose of it properly......however that is. Or you can just dump it out in the dirt.
    Then, rinse it out with a garden hose and a strong nozzle. Wear eye protection. Rinse it until it stops puking out crap and the water is CLEAN. Then drain it of all the water. Now, go to your local O'Reilly (see how I worked that plug in?) and buy some fresh battery acid. It comes in a six quart container and it's CHEAP. Refill the battery and slow charge it overnight. It will likely last another ten years. My best friend has one Daddy bought new in about 1974 "or so". I did the above procedure to it when I got it from Daddy in 1982 "or so". Then I emptied it out and gave it to my best friend about 1995 "or so". It was still good. It still is good. He keeps it on his work bench as a decoration because it was made with colored plastic and it looks super cool. No stickers. I guarantee you he could refill it charge it up tomorrow and it would still be good. They go bad from all the crap and mineral buildup from over the years. If you flush that out before the battery completely dies, you have a very good chance to save it. You'll be trading down if you get rid of that battery. They don't make them like that anymore. I would try to save it if it was mine. The acid is less than 20 bucks and the labor is free.
    • Like Like x 4
    • cchrishefish
      466
      59
      Oct 22, 2009
      Syracuse, NY
      Local Time:
      9:45 PM
      Now this is some good information, but I am thinking that some good cheap distilled H2O from Walmart may be the flushers choice. Should I give this a trial run?
    • RustyRatRod
      50,183
      16909
      Jun 7, 2010
      Georgia
      Local Time:
      9:45 PM
      Use tap water to flush. no need to buy water. Since you're not leaving it in the battery it doesn't matter. You'll be filling it with fresh acid only.
      • Like Like x 1
      • Agree Agree x 1
      • 604B1duster
        604B1duster Well-Known Member
        1,099
        368
        Dec 30, 2007
        Local Time:
        7:45 PM
        Well, times have changed. About 2 yrs ago my father called me to have me come install a die hard gold he got from sears. . Almost 300 bucks. I told him he was crazy...........
        It was NFG in 6 months.
        • Like Like x 1
        • Hellrats
          Hellrats Still wrenching after all these years FABO Gold Member
          945
          681
          Jan 24, 2012
          N.E. Ohio
          Local Time:
          9:45 PM
          The old batteries were great. I myself have done the flush and refill like Rusty said and have had mixed results. As long as it is just junk on the bottom of the battery that is shorting out the plates you do have a good chance of saving it. Best I have got was 9 years out of a battery. Now the new batteries are shitty for sure.
          • Like Like x 1
          • j par
            j par Well-hung Member
            13,360
            6043
            Jul 2, 2014
            Portland Oregon
            Local Time:
            6:45 PM
            Personally I go up to the battery Exchange and get a reconditioned battery. For 40 bucks it comes with a one-year warranty and I never had one die on me yet. I sold my gold Chevy truck about 3 years ago and it had one in it for 6 years until I sold it working fine. I put one in my last Durango 4 years ago and just sold it with that 74 truck and it started it just fine. My-2
            Personally I'm not going to flirt with battery acid for 40 bucks or to save 20 which I would never save Because by the time I actually poured it into a container and drove it all the way to the proper disposal place and pay the $5 disposal fee I would be out more gas money and time then I would ever save.
          • zkx14
            zkx14 Duster De-ruster FABO Gold Member
            19,348
            11883
            Dec 23, 2012
            South Central PA
            Local Time:
            9:45 PM
            Diehard Gold in my mower is 9 years old. Still worked last season, but think it's getting tired. Need to work on the mower before I try it again though. 1994 Wizard with a 20hp Kohler. Think its time for a new carb. Maybe a couple other things... Was just thinking about it looking at the grass this morning. Not growing yet, but can see it greening up a little. Couple warm says and it will go nuts. Might be push mowing first cut...
          • robert flippo
            robert flippo Well-Known Member
            147
            93
            May 9, 2018
            gibson station va
            Local Time:
            9:45 PM
            My next door neighbor sells batteries for lawn mower,cars,tractors, trucks ,etc, he is a distributor,i was complaining about batteries in my mower lasting about 2 years and then having to jump start them,and replacing them every 3 years, he said in a lead acid battery when i got it new to put an aspirin in 1 of the cells and it battery life would be extended, so 8 years ago ,i paid $24 for a battery ,put in the aspirin and after i junked the craftsman i had it in, i moved it over to my cub, and it starts every spring without charge and sitting all winter, my neighbor who told me that said he was on 12 years on his mower battery, so i am curious to see how long mine last, but as for now started last week and i got the leaves from my oaks mulched up .
            • Like Like x 3
            • Thanks! Thanks! x 1
            • cchrishefish
              466
              59
              Oct 22, 2009
              Syracuse, NY
              Local Time:
              9:45 PM
              I read an article which indicated that AGM batteries do not usually recover after losing a charge. For someone who stores their vehicle during long harsh winters, this is a concern. Is this a true fact?
            • 67autocross
              67autocross A new iron curtain drawn across the 49th parallel
              1,038
              469
              Jul 23, 2010
              Winnipeg
              Local Time:
              8:45 PM
              My friend has a 94 Dodge pickup that he bought new in August of 1993 and it still has the original battery in it.
              • Like Like x 1
              • 72Duster440
                72Duster440 Well-Known Member
                337
                61
                Aug 2, 2010
                Sterling Heights, MI
                Local Time:
                9:45 PM
                Best I can tell, the red top in my Duster is from the mid 2000's, so going on 15 years old. I've killed it a few times down to 3-4 volts when the brake lights stayed on, a super slow trickle charge has brought it back to life a few times. Now that i said something, I'll probably be in the market for a new one this spring. Lol
                • Agree Agree x 1
                • cchrishefish
                  466
                  59
                  Oct 22, 2009
                  Syracuse, NY
                  Local Time:
                  9:45 PM
                  So, my Die Hard Gold 24 F battery cost me $80.00 after tax in 2009 therefore, it has a yearly cost of about $8.00. Current cost is $120. Doing the same math on a Red Optima, current cost $232 minus 50%, which should be the price in 2009 if compared to the Gold battery current increase, now we are at $116.00, divided by 15 years, equals a yearly cost of $7.73. Very close in bang for the buck if the 2009 price is accurate. See, math can be fun!
                  • Like Like x 1
                  • Pascamp
                    Pascamp Well-Known Member
                    775
                    642
                    Feb 27, 2016
                    PA
                    Local Time:
                    9:45 PM
                    I'll regret saying this. I haven't replaced a car or truck battery in over 20 years. My vehicles are all driven A LOT though, and never sit. Motorcycle and tractor batteries I change like socks though.
                  • Dartnut
                    Dartnut I put the ''Hoar'' in Hoarding
                    9,934
                    1922
                    Apr 19, 2007
                    Southern Alberta
                    Local Time:
                    7:45 PM
                    Personally, i like Rusty's idea of dumping the old acid in the dirt and flushing it out with clean water.
                    You could probably fill a 5 gallon pail with the old stuff including the flushings and drive across town to dump it so you don't get caught dumping it near your home.
                    I would go at midnight, under a full moon, and dump it in your least favorite politician's back yard or alley.
                    And then howl at the moon..................
                    Awoooooooooooo!
                    • Like Like x 1
                    • cchrishefish
                      466
                      59
                      Oct 22, 2009
                      Syracuse, NY
                      Local Time:
                      9:45 PM
                      Or perhaps, since it is an acid, maybe I can neutralize it with a base. Baking soda?
                      • Agree Agree x 2
                      • RustyRatRod
                        50,183
                        16909
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        9:45 PM
                        I've been with O'Reilly now 4 years in May. We have a very low warranty return rate for the Super Start batteries. They are made by two companies. Johnson Control and East Penn Battery company. Most of our cores are the Autocraft batteries from Advance. We get very little Duralast batteries from Autozone. It might be a regional thing, because we live in a pretty mild climate. I do agree 100% that batteries are nothing like they were.......but then, what is? Corporations figure out that they can make product cheaper and cheaper and consumers will still buy it.
                        • Agree Agree x 1
                        • zkx14
                          19,348
                          11883
                          Dec 23, 2012
                          South Central PA
                          Local Time:
                          9:45 PM
                          Good battery acid is about 35% sulfuric acid. Used in drain cleaners at 80-90%. I'd pick your worst drain and use it. I never did it, so not sure how the reaction will compare, I would take same precautions. Ventilate ,cover drain etc... I have used the heavy duty drain cleaner, which will boil, spit, make nasty gas etc. and should not put it in a septic tank could screw up the bacteria.
                          Yes it can be neutralized with baking soda.
                          At the warehouse, our battery room drains filtered through a pit of limestone so no separate washdown area was needed. That was only intended for washdown and minor overflows though. Not dumping. For a direct spill we usually threw baking soda on it. If
                          you are going to start a battery revival business, you will need a way to handle the waste acid. Or you might not have any metal pipes left after a while.
                        • 4spdragtop
                          4spdragtop FABO Gold Member FABO Gold Member
                          25,429
                          4862
                          Aug 28, 2009
                          Ontario
                          Local Time:
                          8:45 PM
                          OR take the battery acid to a hazardous waste dump? Same place used oil goes, it costs me the price of fuel to drive and dispose of it.
                          I have 3/4 of a box of new acid I've had for 15 years. Can't find batteries with the pop tops anymore....
                        • Dusty2
                          Dusty2 Well-Known Member
                          53
                          52
                          Aug 15, 2010
                          Winnipeg, Manitoba
                          Local Time:
                          8:45 PM
                          I had a Mopar battery in my 75 360 Duster for 12 years! I drive aprox 500 miles a summer and the car is stored in the winter. The only reason I changed it, was a mechanic friend said "one day it will let you down at a car show"! I didn't want that to happen! Yes, I replaced with another Mopar battery! Hopefully, will last as long.
                        • RustyRatRod
                          50,183
                          16909
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          9:45 PM
                          You can simply neutralize it as outlined with baking soda. Cheap enough. Then just let the ground absorb it. Won't hurt a thing. We use soda ash at work to neutralize acid spills. Same thing, just in a cheaper bulk form.
                        • 4spdragtop
                          25,429
                          4862
                          Aug 28, 2009
                          Ontario
                          Local Time:
                          8:45 PM
                          Hazardous waste/dangerous goods is called that for a reason. You cant neutralize all of it by sprinkling baking soda when you dump it on the ground lol. It might work for a contained area.
                          Mother Nature is a great "filter" but we abuse the shit out of her.
                          This is the reason I went to tree hugger school, job security lol
                          • Agree Agree x 1
                          • moparmat2000
                            moparmat2000 FABO Gold Member FABO Gold Member
                            12,332
                            2616
                            May 13, 2010
                            Grand Tetons
                            Local Time:
                            8:45 PM
                            You put the acid in a container, and neutralize it with baking soda before dumping it out.
                            • Like Like x 1
                            • RustyRatRod
                              50,183
                              16909
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              9:45 PM
                              Exactly. No way would I just dump it out on the ground and dump soda on top of it.
                              • Like Like x 1
