[WANTED] 12" (11.75) Pin Type Brake Caliper Brackets
72DMag
Pittsburgh
Hi does anyone have the larger 12" actually measured as 11.75" pin type brake caliper brackets for sale? I received a project car and it has all the parts (brake caliper, rotors, and pads) but no brackets.
Can be off of any car but a C Body. They use a wider bolt pattern on the spindle.
I can pay via paypal (will cover fees), venmo, or money order.
Need shipped to pittsburgh pa area. Thanks!!
@rbkt65 I heard the D150 line are the same. I need them to measure 3 1/2 inches from center of mounting hole to center of pin hole. The 2 mounting holes should measure 3 1/8 inches from center to center. Pic below for reference.
I think that Dr. Diff has them listed on his website... but I don't have
any idea who makes them. Hope you find what your looking for.
I haven't had 11 3/4 brackets for either the pin type, or slider type calipers, for sale, in quite a long time.
Cars that they come on, do not show up in the Pick-N-Pull wrecking yards anymore.
Time has marched on.
DoctorDiff sells the slider type 11.75” brackets, not the pin type. The pin type brackets are not currently reproduced, you have to find originals.
I have pulled them off of Cordoba's, Charger Daytona's (look like a Cordoba) Magnums, and B body late 70's Fury's. But like Jimmy V. said above...that ship has mostly sailed and they are very hard to find anymore. Best of luck to you.
Thank You everyone!! Worse case scenario I'll get the 11" rotor or swap to the slider brake calipers. Thanks again. Will leave ad up for little bit just in case
Well, if you are switching to slider calipers, then you can use the Dr Diff slider caliper adapters.
